My #!&*#! sub doesn't stop moving around the trunk!
Old Apr 23, 2003 | 01:10 PM
MontrealCL's Avatar
I need to have my SUB centered in the rear of my trunk (so that I can see it from the backseat opening. The thing is that it doesn't stop moving around when I'm driving... Any tips on how I can make it stay in place?
Thanks,
MontrealCL
Old Apr 23, 2003 | 01:17 PM
brianlin87's Avatar
ASM I.S. Design FTW.
bolt it down with brackets
Old Apr 23, 2003 | 01:26 PM
MontrealCL's Avatar
With brackets? I don't know if that's the type of installation I want to do in my trunk... I remove my sub once in a while (when I need the space), so bolting and unbolting it would be too time consuming.
I was thinking of maybe getting a piece of wood the width of my trunk and bolt the sub to the piece of wood, that way I could remove everything together... And it shouldn't move aroud...
Any comments?
Old Apr 23, 2003 | 01:27 PM
gsxr151's Avatar
Valcro...
Old Apr 23, 2003 | 01:34 PM
Titand19's Avatar
East Coast Boost.!
Put a sheet of soft rubber under the sub box so it doesn't slide. like the kid you put under carpet or table matts
Old Apr 23, 2003 | 05:04 PM
Rod's Avatar
Rod
Velcro
Old Apr 23, 2003 | 05:45 PM
icy CL's Avatar
Originally posted by Rod
Velcro
i second that. better if you can get heavy duty velcro from home depot. mine hasn't moved since i put it on....four long strips on each edge.
Old Apr 23, 2003 | 09:35 PM
chef chris's Avatar
Homeless
2 words...Vel & Cro
Matches the trunk area also, almost invisible.
Even a few small pieces will hold a big sub enclosure. I use it to steady my toolbox when I put it in the trunk.
Old Apr 23, 2003 | 10:28 PM
SilverKnight's Avatar
Retired. Not available.
Did anyone say velcro?
icy,
I think you meant to say "1" long strip on each edge
Old Apr 24, 2003 | 12:37 AM
Nicky Pass's Avatar
Fuct in the hed!
Lock and Loop.....its like Velcro.....but waaaaaaaaaay stronger!
Old Apr 24, 2003 | 10:30 AM
spdy0001's Avatar
I now drive an accord....
The solution for my old sub setup was a trip to the local dollar store
I picked up some of this real thin stuff that is sold in many colors, its sold in a roll and its like non slip or something. I cut it in half and put half under each side of the sub and it never moved again. The greatest part is that it is in now way permanent
Old Apr 24, 2003 | 10:50 AM
NSXNEXT's Avatar
Definitely the heavy duty velcro from Home Depot.
Old Apr 24, 2003 | 11:19 AM
icy CL's Avatar
icy,
i did say velcro, right? shud-up silver! he knows what i meant!!!
PortlandRL
Sep 14, 2015 12:01 PM
Sep 14, 2015 10:48 AM
kuzdu
Sep 10, 2015 08:42 PM
asahrts
Sep 4, 2015 05:55 PM
dlknight
Sep 3, 2015 07:54 PM
