Mute control of entertainment system
Old Jul 23, 2005 | 01:54 AM
scottstsx's Avatar
7th Gear
I've seen posts about using pin #14 on the HU to cause the system to mute. Does anyone know if this includes "muting" the climate control system as it does when you press the voice button -- if the climate control is blowing air from the dash it cuts out while it is waiting for you to speak.
Old Jul 23, 2005 | 09:59 AM
elduderino's Avatar
VP Electricity
I've never tested that - but I'd bet one million dollars against it.
Old Jul 25, 2005 | 11:32 PM
Tsx536's Avatar
Rep'n Taxbrain.com
I've tested the mute signal on pin #14. It works and does in fact mute the stereo. The harness is plugged directly into the back of the HU headunit, so I doubt that the stereo would be controling the a/c unit itself.
I'm guessing the a/c unit must have it's own input to tell it to stop blowing air. If you can get a hold of a Helms manual you should be able to look this up.
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
Sep 17, 2015 09:01 PM
