MB Quart fit in TSX???
Old Jul 5, 2006 | 05:09 AM
ultragamma's Avatar
Hi, i was thinking of changing the front door speakers and dash tweeters with MB quart components. Anyone had try them and if they fit or not? Can someone also confirm me on the spacer thickness? 3/4 or 1 inch?
Thanks..
Old Jul 17, 2006 | 02:25 AM
LOL888's Avatar
P-series fit for me
Old Jul 19, 2006 | 08:06 PM
TallestTSX's Avatar
Given that their P-series' mounting depth for the 6.5s (2.5") is the same as most of their Q-series 6.5s (2.5" also), you should be fine with either. However, note that their new "Q 216 SIG 6.5" has a mounting depth of 2.58", and that's pushing it.
Old Aug 3, 2006 | 08:59 PM
supraken's Avatar
Anyone try using stock amp with these speakers? How do they perform??
Old Aug 5, 2006 | 08:36 PM
offset_98's Avatar
I too am interested in this question...thanks.
Old Aug 12, 2006 | 11:25 AM
VegaTSX's Avatar
Unauthorized User
The MB Quarts will fit in the TSX i am running MB Quart QSC 216 Components in the front they replaced the stock 6.5 and tweeters fits fine, I am also running MB Quart RCE 269 6x9 in the back and they fit perfectly. I am not using stock Amp however it's powered with Rocford Fosgate P4004. They were professionally installed so i can't explain how it's being wired etc..
Old Aug 17, 2006 | 10:22 PM
jdmturtleracin's Avatar
i have MBQ Q-series up front...the tweeters will fit into stock locations... i used a spacer for the 6.5's in the door...running them off xtant 2002i...
Old Nov 1, 2006 | 12:16 PM
bullyx2's Avatar
'05 TSX CG W/NAV
Would any of you with the quart tweeters in the dash be able to post a pic or email me one. (bullyx2 at gmail.com) I am going to be replacing the speakers in my TSX (not the 6x9's though) and am digging for pics of replacement tweets in the dash. Thanks!!!
Old Nov 1, 2006 | 12:27 PM
elduderino's Avatar
VP Electricity
You might want to read Jiggaman's posts about how he has finally decided his tweeters sound bad.
I don't like MBQ tweeters anyway, but in the dash? That's asking to saw your ears off.
Almost any tweeter can be wrapped in grille cloth and will look fine.
Old Nov 1, 2006 | 12:39 PM
bullyx2's Avatar
'05 TSX CG W/NAV
was thinking the same thing on the quarts (and infinity as well which I have used alot in the past). too bright. you sell the DLS ones, correct? what is your price on those?
Old Nov 5, 2006 | 03:41 PM
JIMMYNGUYEN110's Avatar
3rd Gear
Hi
Will this fit a 2001 cl type s?
Old Nov 6, 2006 | 11:52 AM
elduderino's Avatar
VP Electricity
I know the 0.75 Quart tweeters will fit. The 1" tweeters would be close and would involve modding the inside of the sail housing.
The door spacer water shield will need a good bit of mod, but it's only plastic.
jriv7
May 8, 2020 05:50 PM
Gabru678
Apr 24, 2019 02:36 PM
acura_dipset_tl
Jan 1, 2016 03:02 PM
leerbgdup
Sep 6, 2015 11:01 PM
obert
Sep 3, 2015 08:40 PM
