Mac Mini + 2 jl amps
Old Dec 21, 2005 | 06:08 PM
chiTSX's Avatar
ok, so i've been working on this project for almost 4 months now. Here's what I have:
JL 500/1 Mono block
JL 12w6v2
JL 300/4 with sublevel out
Mac Mini
i plan on removing the factory amp and going direct from the head unit. what i need to know is what else do i need? i am planning on getting that sony honda adapter. will that allow me to connect the mac mini to the head unit, or should i go straight from the mac mini to the amps? my only concern with the latter is that the mac mini audio output is only 2 channels. i can buy a 2 to 4 channel adapter for the mini, but i was wondering if the sony/honda adapter or the head unit do this already. i plan on using the stock head unit for CD play back, but I would like to retain full navi function with the mini for MP3 playback.
i also want to know if there are any factory audio wiring harness adapters for use with the tsx head unit. essentially I want to find a black box of some sort that will let me connect the head unit's line out wiring harness to 4 rca females.
any input on this would be greatly appreciated.
2004 TSX + navi + 6spd, 48000 miles
Old Dec 21, 2005 | 06:26 PM
elduderino's Avatar
VP Electricity
The OEM HU takes 2-channel in the AUX input and then does split F and R thoruhg the OEM fader. No problem there.
I still haven't seen any harness like the one you speak of... it would help, but I still haven't seen one.
I would plan on using a ground loop isolator on the output of the Mac mini... as far from the back of the HU as possible to avoid it picking up ECU noise.
Old Dec 22, 2005 | 02:58 PM
Spoon's Avatar
Nah, you gotta DIY it. Good luck, post some pics when you have it working.
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
