Lock Beep
Old Dec 10, 2004 | 08:31 AM
MoFocker's Avatar
Lock Beep
help mods, i dont know what section this belongs in
Anyone find out how to make an 04 beep when you lock it. trying to avoid any heart failures this winter from my confirmation locking sound
Yes, im aware there are a handful of other topics about this, but there sorta just thrown into other discussions...
Old Dec 10, 2004 | 09:08 AM
CGTSX2004's Avatar
Find out what the difference is between the 04 and 05 and then just get the parts from the 05 and install them. That's about the only way I can think of to make this work.
Old Dec 10, 2004 | 10:57 AM
TSXsurf's Avatar
NBP/EBONY/6MT
but what is the difference? you should research.
Old Dec 15, 2004 | 11:33 AM
MoFocker's Avatar
anyone find out yet?
Old Dec 15, 2004 | 11:34 AM
MoFocker's Avatar
or should i say, does anyone have access to a parts diagram?
Old Dec 19, 2004 | 05:40 PM
MoFocker's Avatar
its me again being a pain in the a** and asking again
Old Dec 19, 2004 | 10:09 PM
Dan Martin's Avatar
Photography Nerd
I'm going to move this to the A&V section to give our electronics guru's a shot at it.
Old Dec 20, 2004 | 12:30 AM
elduderino's Avatar
VP Electricity
Get a voltmeter.
Buy this beeper:
http://www.radioshack.com/product.as...t%5Fid=273-066
Find the wire in the kick panel that triggers (-) off of the door lock switch, but NOT off of the remote. (See the sticky on alarm wiring).
Find another wire that triggers (+) when the doors are locked for any reason (again, see sticky for Dr door unlock wire, test both for this description, (+) on lock).
Get two standard automotive "Bosch"-style relays.
http://www.autotoys.com/x/cust/produ...8&cat=0&page=1
Connect Relay 1 as follows:
85 to lock (-) switch wire in driver's kick panel.
86 to lock (+) wire in driver's kick panel.
87A to (-) ground
30 to (-) terminal of the Piezo
Other piezo terminal goes to ground.
Every time the remote is used to lock the doors the piezo would beep. Every time the switch is used to lock the doors the piezo is prevented by beeping by the relay.
It is remotely possible that there would be a millisecond chirp from locking with the switch. If this is true we can insert another relay (#2) to lessen the time, and worse case, we can come up with another solution. It really depends on how manymilliseconds it takes this piezo to make a sound, and I am depending on the capacitive-charging of the piezo to take long enough to make it no problem at all.
Old Dec 20, 2004 | 03:43 AM
PixelHarmony's Avatar
Master Graphic Artist
elduderino is the master of a/v
Old Dec 20, 2004 | 04:48 AM
einsatz's Avatar
I miss my 03 CL-S :(
Wouldn't that make it beep every time you lock the doors with the remote? That is, if you hit the door lock button, it'd beep. If you hit it twice, it would still honk the horn (and beep?)?
So you're not replacing the horn with the beep then? I may be misunderstanding.
Old Dec 20, 2004 | 05:05 AM
I think I'll just go with the whole aftermarket alarm deal once I get $$$
Old Dec 20, 2004 | 10:22 AM
elduderino's Avatar
VP Electricity
I didn't get that I was supposed to eliminate the honk, I just got that he wanted beep. I've theorized on how to get rid of honk before, but it hardly seems worth it -the OE alarm arms 30 seconds after lock on one press, so no reason to press twice if you have a beep on the first press.
Old Dec 20, 2004 | 12:56 PM
elduderino's Avatar
VP Electricity
Oops. I f*cked up! : )
This would not beep at all. The other side of the piezo has to go to 12V(+), not ground.
Guess a hot would help ...
Old Dec 20, 2004 | 01:41 PM
MoFocker's Avatar
woah, thats some good info. i cant even begin to think of attempting anything like that without causing a car fire .
but hes right, i meant and assume that the others who are interested, meant to replace the horn confirmation honk with the digital beep that the 2005 makes. I cant imagine it being more then a simple new horn or alarm node or something. probably not worth doing if its more intricate then a plug-n-play process; for me at least.
thanks though
Old Dec 20, 2004 | 02:14 PM
elduderino's Avatar
VP Electricity
The 04 has a horn output that it pulses for the lock honk and also for an alarm trigger. The two functions are built into the single output at the software level. It is difficult to change one and not change the other, but it can be done.
If the 05 beeps instead of honking, then it has a seperate output for a piezo beeper, or it's beeping something else (is it the same beeper as "leaving lights on"? In that case it's already built in and is just different software.) I don't think Honda built in more parts cost just so there was a beep, so I suspect they are using existing hardware in a slightly different fashion. I've never played with an 05, so I am not certain how to duplicate its operation exactly.
An experienced alarm installer could execute what I describe safely and reliably. I don't know where you are, but there may very well be a local shop that can be trusted with such work.
Old Dec 28, 2004 | 10:29 AM
MoFocker's Avatar
just resurecting this thread to see if anyone has an update
Old Dec 28, 2004 | 12:24 PM
elduderino's Avatar
VP Electricity
WHat, you don't like MY answer?
Old Dec 28, 2004 | 12:29 PM
Whiskers's Avatar
Go Giants
The horn lock sound doesn't bother me
Old Dec 28, 2004 | 01:02 PM
TSXsurf's Avatar
NBP/EBONY/6MT
Apparently not. Maybe you should ask the dealer to make it happen if you dont want to do it yourself.
Old Jan 2, 2005 | 08:54 PM
Xtremespeed2102's Avatar
hmnmmm i usta have a "cricket" schematic. basically an anolog circuit that would make a piezzo churp like a cricket either always or when something tiggers it...... could be useful some how but that would then reuqire quite a bit of electornic knowledge
MrHeeltoe
20
Feb 23, 2023 01:54 PM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
