Just added an AMP to the CL, but...
I just added Fosgate P4004 to my 2001 acura CL. I used RCA line converter from Best Buy. The AMP does work and there are sound coming from my Punch subwoofer. The AMP does 200Watt X 2 channel to my two 12" woofer. The only problem I have is the bass from the subwoofer is not strong enough or not loud enough. I was thinking this could be due to the head unit not having a bass setting. Do I need to add an EQ to make the bass sound good and loud or do I need a stronger AMP. I already tried to adjust the level of the AMP, but it still not good enough for me.
Before I have the Acura CL, I have Acura Intregra. I used JVC head unit, Sony Amp (this is older amp and has less power than Fosgate amp), and with the same woofer. The bass sound really good and loud even though the Sony Amp was not that powerful. From this comparison, I believe the Acura CL head unit is preventing a good bass signal to the Subwoofer.
Originally Posted by NICKTL
is the rf amp going straight to the stock hu? did you disconnect the stock amp and take out the 9" stock sub?
Does the line output converter have a gain setting? Set it to the max. If it already is, it still might be knocking the voltage down on the signal coming out of the head unit too much. You should use different LOC that converts speaker wire to the RCA's but does not reduce the voltage since your most likely using a signal that's preamp level. I believe soundgate makes such a LOC, i'll have to double check.
Originally Posted by Xrock
Yes, it does. LOC is ICE AULOC. They are part of the Rockford Fosgate company or division. I try to adjust it, but it only helps a little bit. Does a different LOC make that much of a difference or better?
Originally Posted by dark inspire
yeah where exactly did u tap the wires from, because when i installed a system on a CL we took it from the rear speakers. Also, did u check ur powerwire?
When you installed the LOC to a CL and I'm not sure which Amp you used, but does it sound good and have plenty of bass?
Does the CL have a separate sub like the TL does? If so, it might be limiting the bass to the back speakers from which you tapped into?
Tap the wiring from the back speaker (LOC). The power is tap directly from the battery using 4 Guage thick wiring. The remote is splice from the factory amp. I'm happy there are some bass to the car, but not over joy because it is still not enough. Maybe I need to replace the head unit with after maket one, which probably would cost a lot more than the LOC.
Looks like you did everything like i did, but did u use just one Channel into the LOC or 2. I hooked up a JL 500/1 and a 10W7 and it seemed to work fine.
as far as i know the CL does not have a stock sub, only two 6x9's in the back.
Originally Posted by CJams
Is your sub hooked up backwards?
InFaMouSLink
10-30-2015 09:43 AM
4drviper
09-23-2015 09:00 PM
