JL Audio
Old Aug 11, 2003 | 03:02 PM
SatinSilver3.2's Avatar
A-CL Master
JL Audio
Will 3 10 inch W0s in a power wedge box sound good in a Acura CL 3.2. Or should I just get one big JL sub?
Old Aug 11, 2003 | 03:03 PM
A-CL Master
I will run with a rockford power 351m amp.
Old Aug 11, 2003 | 03:21 PM
BEETROOT's Avatar
Yeehaw
personally I would rather get one bigger, higher quality sub than 3 smaller subs. I think the model is a 13w7...pretty nice.
wouldnt take up your entire trunk either, if thats a consideration.
guess it depends on what your going for, spl, rattling windows down the block as you drive, or just quality bass.
Old Aug 11, 2003 | 06:21 PM
A-CL Master
this is what i am getting which i hope will fit in the very back of my trunk.
http://www.jlaudio.com/enclosures/CS310RGW0.html
I want it to be loud with a lot of bass and then i am worried about quality spl/bass. I cna't afford a 13 inch w7. Kinda want to stay under 700 for the whole system.
Old Aug 11, 2003 | 07:22 PM
Nicky Pass's Avatar
Fuct in the hed!
My 1 10W7 is amazing...I'd highly reccomend it!
Old Aug 11, 2003 | 07:29 PM
BEETROOT's Avatar
Yeehaw
yeah well that will sound real good...just saw lexus ls430 and bmw x5 on your signature...assumed money was no object
Old Aug 11, 2003 | 08:18 PM
sonor kid's Avatar
One who Laps
Power it with a JL amp, as they seem to put out more power than many other amps I've had in the same class.
This because the use a regulated power supply.
Stay away from Rockford, weak in my opinion.
Old Aug 12, 2003 | 03:54 AM
BEETROOT's Avatar
Yeehaw
rockfords are weak? hmmm
Old Aug 12, 2003 | 03:57 PM
A-CL Master
i am cheap when it comes to accessories. wasted money on nice cars.
Old Aug 12, 2003 | 07:35 PM
A-CL Master
So I need to know if I should go with the 3 10in W0s or not with the rockford 351m... I want it to be loud but also want to be able to hear words and have a alrihgt quality. Am I asking to much of these W0s? Talked to the guy today and he said if I went with one 12in W6v2 it would be another $400. Tomorrow I plan to get the 3 unless something changes my mind.
Old Aug 13, 2003 | 01:10 AM
KyleWatson's Avatar
That is the wrong setup for that amp....
That amp is 2 ohm mono stable, and three SVC 4 ohm subs will be a 1.33 ohm load. The amp will go into protection, I'd pass.... If you are going for loud, can you build your own box? Do you have any access to a wood shop that you wouldn't have to pay for?
If so, I can get you specs for a box with a single Eclipse 12, that would easily be louder than the 3 W0's.... The only issue is it's a tight fit for the sub, and can be tough to build if you don't really have any experience. Our shop charges $350 for the box alone, which would not fit in your budget.
Power wise a 351m would run the sub just fine, but I would still recommend a 451m...
As far as JL's having more power than other amps, I would disagree.... They are a 5 year old Xtant design, and they cheaper parts. They are still good amps, and there are many more with regulated power supplies, that give you more for your buck. A regulated power supply means that with a lower voltage, the amp will draw more current so that it can put out the same amount of power. This has advantages and disadvantages, one advantage being no loss of power with wipers, lights, and heater on.... A disadvantage is that it draws more current bogging down your alternator.
I would personally never purchase the current JL amps, but that's only because they're old technology, and a hefty logo price tag. They are very practical for most use, and very flexible, just expensive for what you get (you have to pay alot for that JL logo).....
As far as I'm concerned, get one better sub, or two better subs...
If you were to do a 4 speaker system inside of your car... Which would sound better, 4 good speakers, or 2 Great speakers, with the rears just as a little bit of rear fill?
Hope another drunken post was proof read okay.....
Old Aug 13, 2003 | 03:02 AM
dnd2984's Avatar
IF u want loud then do the RF 351m and get 2 W0 12's. or One W3v2 12. I mean if u want to sacrifice all that room them go for the 3 10s in the powerwedge box. Also the 3-10's have a 2.7ohm imped, they are 3-8 ohm woofers. Now since its a 2.7ohm u wont get a tru 350 watts to them either. From top of my head I can only think of a Kicker 400.1 would be a better choice than the 351m, The next in fosgates line is a 500bd but that will be a bit much for those woofers. I have heard 2-12W0s with a 200 watt amp and that shit really banged.
Old Aug 13, 2003 | 04:11 AM
dets's Avatar
2004 Euro Cup Champions
3 WO 12's?!?! i wouldn't settle for a that system at all. You said you were going for cheap right? what i would suggest is going on ebay and buy either 2-W3v2 12" subs. even one 12W6 would even be a better fit. thanks for my friend kyle, i undestand exactly what type of power you should be running to your system. Run the whole thing off a 4 ohm 300 watt amp(i'm not selecting brands just a generally pick) and you're box should sound fine. more speakers is not always better. also, you should reconsider the price. 400 for 3 of the shittiest speakers jl audio has to offer sounds like a rip off to me.
Old Aug 14, 2003 | 03:33 PM
BEETROOT's Avatar
Yeehaw
^I agree with dets...more does not mean better. take the $ you want to spend for the 3 speakers, and just buy one that is three times better
Old Aug 14, 2003 | 04:37 PM
A-CL Master
I actually got my stuff installed yesterday. I got 2 12inch W0s instead of the 3 10 W0s. It sounds really good but now I have to stop the spoiler from rattleing so bad. I will post pics later.
Old Aug 15, 2003 | 03:52 AM
dnd2984's Avatar
thats good to hear. How do u like the JLs so far? I got my W7 installed yesterday with a JL 500/1 and the SQ is awesome but just not loud enough so I am gonna get a ported box next.
Old Aug 15, 2003 | 03:17 PM
A-CL Master
I like the JLs a lot but the only problem is the rear rattleing like a mofo. W7 are way down the road for me but congrats bout that. I got them to wire the bass knob up to the front near the TCS button and Cruise control. I love it.
Old Aug 16, 2003 | 08:39 AM
brianlin87's Avatar
ASM I.S. Design FTW.
aren't W0's weak?
Old Aug 16, 2003 | 02:45 PM
dnd2984's Avatar
Originally posted by brianlin87
aren't W0's weak?
They only handle about 150 watts but they sound awesome and do get very loud with just about 100-150 watts. I have heard one W0 10 with 150 and it banged, and also heard 2 12s with 200 watts and didnt believe it was only 200 watts.
Old Aug 16, 2003 | 08:54 PM
A-CL Master
yea i like them. They are loud enough for me and they were the shit back in their day.
Old Aug 18, 2003 | 05:30 PM
dets's Avatar
back in the day is right. congrats on the subs though. good luck with them
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
ValdezQ26
Oct 1, 2015 04:48 PM
navtool.com
Sep 25, 2015 05:15 PM
