JL 10w7 question
Old May 22, 2004 | 03:28 PM
Got_3.2?'s Avatar
JL 10w7 question
how many decibals when getting metered should this sub be putting out???
just 1 10w7 with JL 500.1 amp with my stock headunit bass knob and my JL bass knob turned all da way up??
thanks
mike
i dont think i did to good but ill post wut i metered afta wut ppl think it should be at..
BTW i was using Freak a leak as my weapon of choice today in da sound off lol.
Old May 22, 2004 | 03:43 PM
Nicky Pass's Avatar
Fuct in the hed!
In my CL it hit 135.6. My buddy had the same set up in a blazer...in a ported box and he hit 142!!!!
Old May 22, 2004 | 04:11 PM
Got_3.2?'s Avatar
wow!!! i only hit 125.. can it be my amp settings? since i did mess dat up big time... also i didnt dynamat my trunk yet would dat help my dB?? i was shocked.. atleast my 1 10w7 hit harder than sum guys 2 10w7s wit 1 amp for each.. lol
Old May 22, 2004 | 05:29 PM
Hobo's Avatar
Flap.
well dynamat shoudl in theory reduce body panel flex.. which wold increase sound preasure...
Old May 23, 2004 | 10:25 AM
Nicky Pass's Avatar
Fuct in the hed!
Look at the setting in the book that you got with the sub....thats how mine is set!
Old May 23, 2004 | 10:41 AM
Got_3.2?'s Avatar
when i messed wtih ti the 1st time i used the recommended settings JL suggest but it seemed liek my sub wasnt hitting like the way it was set before so i messed with it.
Old May 23, 2004 | 10:48 AM
Nicky Pass's Avatar
Fuct in the hed!
What kind of box is it in!
Old May 23, 2004 | 03:23 PM
Got_3.2?'s Avatar
Custom ported box built to JL specs.
Old May 23, 2004 | 04:07 PM
Hobo's Avatar
Flap.
adjusting the gain on the amp will change everything... im not familiar with all of JL's settings, but the xovers, gain, boost, and ohms (cause its jl) all need to be set correctly to maximize performance.
Old May 23, 2004 | 06:05 PM
Nicky Pass's Avatar
Fuct in the hed!
Set it like in the book...then put the gain at a half.....the play with the bass knob.
Old May 23, 2004 | 07:06 PM
Hobo's Avatar
Flap.
^not the correct way to set the gain
turn the gain all teh way down....
turn the source unit to 2/3 vol
adjust gain to comfortable listening level.
bass boost adjustments should be made to compensate for areas of less spl or volume... the freq of the boost depends on woofer size, box type, enviroment, and music listened to.
Old May 23, 2004 | 11:43 PM
Nicky Pass's Avatar
Fuct in the hed!
I just told him what I did. It worked for me!
Old May 24, 2004 | 11:14 AM
Hobo's Avatar
Flap.
im just saying that turning it halfway up wil not always work... just giving more precise directions no trying to start a fight.
Old Jun 3, 2004 | 09:22 AM
C The "S"'s Avatar
Who built the enclosure? I've seen many people say they built the box to spec and it didn't sound great. If you see the JL built 10W7 H.O. box its much larger than what they recommend in the owners manual. The JL built H.O. box is great.
Old Jun 3, 2004 | 10:06 AM
Nicky Pass's Avatar
Fuct in the hed!
Make sure the fron baffle is atleast 1" thick too.
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
