iPod in my TSX
iPod in my TSX
I want to find a way to listen to my iPod in my TSX and I bought one of those FM transmitters, and was dissappointed in the sound quality. Does anybody know how to have CD quality audio in your car directly from your iPod?
Amcel,
You probably want to look into getting a SNHOND3 adapter that plugs into the harness for your head unit. If you search this forum you'll see a lot of posts on it. I remember seeing a post where someone had step-by-step install pictures. Good Luck
Amcel .. did you not see the sticky thread in this section?
It tells you everything you need to know. Basically buy an aux-in adapter and away you go.
http://www.acura-tsx.com/forums/show...&threadid=3148
Originally posted by tsxer.ca
just get a mp3 in dash.
Amcel330, what transmitter did you try? Was it the Griffin iTrip? Because I just got mine (I have the 3G 20GB iPod) and I find it to work quite well. Mind you, I don't have the 360 Watt Premium Audio system in my car that you have (I don't have a TSX yet), so maybe the annoying nuances of the FM transmission show up worse. However, you're absolutely correct in your assumption that a Line-In solution would work the best. When I finally drop my money on a TSX, I'll definitely be looking into doing this....maybe by then, we'll have some manufacturer that makes a cable that you don't have to cut wires with.....
Originally Posted by miner
no text display on Navi.
Originally Posted by mrcenzo
are you saying this because of all the other responses or have you seen physical proof (not talking about proof via oem mp3 player) of an ice link or icruze attached to the navi?
ive not only searched but ive been following threads related to this all along. the only conclusiveness that anyone has is that the regular icelink. im not too sharp on the differences between the regular icelink, icelink plus or icruze. i just know ive read that the icruze should work with with displays that show id3 info. nobody has confirmed that the navi display doesnt show id3, theyve just made determinations bc the oem mp3 player and icelink dont display anything. theres no way that acura changed the headunit substantially enough to allow id3 tags and text for xm radio. this is just my assumption, im still going to wait until someone has rock hard knowledge that its not going to work.
If the IceLink Plus can't do it, I doubt the iCruze will be able to.
https://acurazine.com/forums/showpos...1&postcount=32
Originally Posted by RMATIC09
So all i have to do is buy a SNHOND3 adapter? for an ipod for my 04 tsx?
4drviper
Apr 23, 2025 07:13 PM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
TLguy42
Sep 26, 2015 11:27 AM
