iPhone 3G PA11 – HON2y issues
So i've used my old 60gb ipod in my 2007 TSX with the USA spec PA11 – HON2y for a while and all is well.
Got the 3g iphone friday and plugged it in and immediately get bugged about it not being supported and it won't charge the iphone. It also sounds pretty flat sounding, but thats another issue.
It didn't charge, which sucks, but everything else worked fine.
Is there a firmware upgrade needed for the new iphones or what?
Does the DICE unit with with the new iphones without any errors?
I've been kicking around the idea of swapping for a while but wasn't sure it was worth it. This might be the reason i needed to swap.
Any help is appreciated. USA Spec's site says it works but not in hybrid mode. No idea what hybrid mode is since its been a while since i installed this.
Originally Posted by UsaSpec Customer Service
>We have designed a new cable that will work with the 3G, Apple changed
the connector dock so all adaptors, not just ours, will not charge the
3G
Otherwise it works ok and it works just fine
It should be ready in abbout 6-7 weeks
Please call John a 215 489 1084 for assistance if you want to get this new
cable
3G
cable
I think i might call him today or tomorrow and check for sure, but i doubt they will tell me.
Was also thinking of contacting DICE to see if they have the same problems as USASPEC said.
LIST/RAMEN/WING MAHSTA 짱
Sanest Florida Man
I have the USA SPec Adapter also. I'm curious if I got this new cable would it still work with the other iPods, I think it'll only work with one or the other.
I'd hope its backwards compatible. Interresting though. If its just a switch in the cable, coudlnt they just make an adapter to make the change instead of a new cable though?
CheeseyPoofs McNut
10-11-2015 11:25 AM
Barb Jackson
09-15-2015 02:27 PM
IndycarFaster
09-11-2015 02:52 PM
