Installing SONY CD changer?
Old Oct 25, 2000 | 04:51 PM
hdp203's Avatar
Post Installing SONY CD changer?
Hi guys,
I just bought a 01TL and I want to put a SONY 10 CD changer that I have in the car (I had the CD changer with my 90Legend). Here are my questions:
1. Does the head unit on the TL have RCA input?
2. Will it be easy if I install using the FM modulator? If yes, where the antenna cable is located on the TL (from the antenna to head unit)?
3. Which way do you think is the simplest way to do it (without having to remove alot of stuff)?
3. Any other susgestions?
Thank you in advance.
Old Oct 25, 2000 | 11:56 PM
StreetEffectz's Avatar
Post
As far as I know, you have to use an FM modulator if you are using a Sony changer in a TL. It's easy to hook up though, you just need to remove the passenger side panel from the console and you can access the antenna lead from the stock head unit there. No RCA input/output on stock headunit.
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
Sep 21, 2015 08:44 AM
TxRzrBk
Sep 17, 2015 01:07 PM
mgbe11
1/2G MDX (2001-2013)
Sep 15, 2015 07:53 PM
