installing amp and sub on 99 tl
Old Nov 26, 2005 | 11:07 PM
purekoryo's Avatar
I just got a 99 TL preimium with navi. I uninstalled my old amp and sub from a 2000 acura integra (which had aftermarket cd deck), and was wondering if the install was as easy on the TL with STOCK cd deck. Is there a link to an installation instruction on this?
thanks in advance
Old Nov 27, 2005 | 11:33 AM
dark inspire's Avatar
El Presidente
there is a detailed post about it, i think its in the sticky section up top. But basically what you want to do is run the power from the battery and what not like normal . Then, you would need to find which wire from the stock amp (located behind the rear passenger-side seat) to tap for the remote wire and then hook up a line out converter and then run the RCA's to ur amp.
AndrewS
19
Mar 14, 2024 06:59 PM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
TxRzrBk
Sep 17, 2015 01:07 PM
Pegon95
Sep 15, 2015 01:54 PM
