installed USA-SPEC w/ nav
Old Oct 20, 2006 | 09:41 PM
umhaha84's Avatar
I just installed USA-Spec,
IT IS GREAT,
it only took me less than 10 min to install it,
1min to pull out compartment,
3min to make a hole on the corner of the compartment for the cable,
2min to connect the wires,
2min to "push" the compartment back in
TIME WELL SPENT!!
Old Oct 20, 2006 | 11:00 PM
Lister00169's Avatar
Yes, he did that
IT IS GREAT,
TIME WELL SPENT!!
Good to hear! Can you post pics of the install process and the end product in action?
Old Oct 21, 2006 | 06:30 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Let me know if you need some help. I'm also around your area.
Old Oct 21, 2006 | 07:33 PM
einsatz's Avatar
I miss my 03 CL-S :(
What type of car, umhaha84?
Old Oct 22, 2006 | 07:31 PM
umhaha84's Avatar
it's 2004 tsx,
hm..my digital camera is broken so i'm gonna have to take pics with my cellphone,
Ill post them up tomorrow
Old Oct 22, 2006 | 08:33 PM
IneedaTSX's Avatar
Is the sound quality as good as cd quality?
Old Oct 22, 2006 | 08:50 PM
Yes, he did that
Thanks dute! I will definetly let you know when I get this.
Old Oct 22, 2006 | 09:09 PM
umhaha84's Avatar
it's perfect for my ears
it's important to find right EQ for your car,
Old Oct 22, 2006 | 09:34 PM
umhaha84's Avatar
in action
Old Oct 27, 2006 | 07:00 PM
amacgeek's Avatar
usa-spec being considered
The USA-Spec iPod interface is one of several interfaces I'm thinking of installing in both my 2K6 TL and 2K5 MDX. Did you encounter a problems with existing audio functionality (ie: did XM, DVD-A, or other built-in audio feature) stop working?
Old Oct 27, 2006 | 07:29 PM
elduderino's Avatar
VP Electricity
Having installed these into the TL like yours, I can state that there is no XM or DVD-A conflict. I know of NO other unit that this applies to.
I can't say definitively for the MDX, but it either won't work at all or it will be exactly the same.
A caveat, though. The TL installation is about 7.5 times more difficult than the TSX installation described above.
You have to remove the side trim on the center console, pull all the screws on the back half of the console bottom, pull the shifter surround, pull the console aft a couple of inches, and pull the bottom screws of the radio, to tip the radio out about 1".
THEN you can reach the plug on the back of the radio, facing up.
Literally in our shop I would estimate this as taking someone 1-1.5 hours if they've done it before. The TSX, I would put at 10 minutes.
Old Oct 28, 2006 | 10:07 AM
Redfish's Avatar
Ticket Slow Drivers
Thanks...we have a TSX & TL. All the info in one place! I have the unit on order for the TSX right now!
Old Oct 28, 2006 | 12:43 PM
einsatz's Avatar
I'm considering replacing my PIE aux input in my 04 TSX+navi with one of these USA SPEC thigns since they charge the ipod. The thing is the PIE has RCA outs which let me run RCA cables to the inside of my armrest which I like. Is the cable out from the USA SPEC unit well shielded?
So if I ran it along the center between the seats under the cupholder and into the armrest, will there be any noise issues? I get zero noise or ground loops with the PIE unit and I'd hate to get some with a new unit.
Old Oct 28, 2006 | 04:35 PM
elduderino's Avatar
VP Electricity
Have had zero issues with ground loops or inducted noise.
Old Oct 29, 2006 | 12:21 AM
Reach's Avatar
I also have zero noise issues on my usa spec, even tho I still have more noise than necessary on my stock aux input. It really is a solid unit. No need for GLIs or anything.
Old Nov 9, 2006 | 08:45 PM
TypeRS's Avatar
Got Ramen?
i just installed my USA Spec and tested it. Works great. Now the problem is having to put the compartment back in which I'm having trouble. Did you guys put the unit inside the cubby box or inside the ...car?
Old Nov 9, 2006 | 10:38 PM
Tsx536's Avatar
Rep'n Taxbrain.com
^^ It's up to you. I'm not sure if you set the dip switch to enable the USASpec AUX input, but if you did, you might want to mount it in the storage bin. You could also just run an RCA to it and put it behind the storage bin and out of sight. The choice is yours really, it just depends on how accessible you want the unit to be.
Old Nov 10, 2006 | 03:34 AM
TypeRS's Avatar
Got Ramen?
i cant seem to fit the unit deep inside such that the cubby box will fit inside...is there really enough space with all the wires and such behind?
Old Nov 10, 2006 | 08:14 AM
Reach's Avatar
Yes, it will fit back there just fine. Pull out the pocket again, and take time to move all the wires aside and fit the usa spec unit as far back against the wall as possible. Then, make sure none of the wires are bunched up or too close to the sides to get caught in the track. If its all the way back there, the pocket will snap back into to its regular place.
Old Jul 5, 2007 | 11:44 PM
kmk42019's Avatar
Quick Question about this particular USA-SPEC!
Is this the model I am looking for? I have an 04 TSX non-navi.
http://cgi.ebay.com/ebaymotors/USA-S...spagenameZWDVW
Also are there any threads that show pics of where to plug it into and place under the HU? Ive done oodles of searching and still cant find it!
Thanks!
Old Jul 6, 2007 | 10:13 AM
Reach's Avatar
Yes, that's the interface you would use. Seach for an old thread started by me on it, there are some install pics a few pages in.
BoricuaTL
Apr 8, 2016 01:08 PM
bymotion
Nov 18, 2015 11:28 AM
TxRzrBk
Sep 17, 2015 01:07 PM
mgbe11
1/2G MDX (2001-2013)
Sep 15, 2015 07:53 PM
asahrts
Sep 4, 2015 05:55 PM
