CL: Installed Aftermarket Deck - Speakers not working!
Old Oct 18, 2011 | 05:25 PM
azeezp13's Avatar
shifting at 7k
Hey everyone,
I have a 2003 Acura CL-S6. So I recently installed my Pioneer AVIC-F700BT head unit. I had a wire harness and matched up all the correct wire colours together. But when I started up my car, the head unit powered on and everything, but there's no sound coming from the speakers!
Can anyone help me with this? Would be much appreciated.
Old Oct 18, 2011 | 05:40 PM
Pretaco's Avatar
6th Gear
Two things I can think of that could do that, make sure the internal amp is "on" in the settings on the head unit, or check for an external amplifier in the car that may need to be turned on with the head unit's remote signal wire.
Otherwise, you got me stumped.
Old Oct 18, 2011 | 05:56 PM
azeezp13's Avatar
shifting at 7k
I'll try that out. If it's worth mentioning, I did a quick search on the forum and found someone else with the same problem. I used a Scosche wiring harness which I guess doesn't bypass the factory amp. Do the metra wiring harnesses bypass the factory amp? If anyone knows... Thanks.
Old Feb 22, 2012 | 07:53 AM
99clprem's Avatar
3rd Gear
i have a 99 with the bose setup had same problem with no sound there is a blue amp wire needs to be hooked up with blue remote wire without it the stock speakers wont play
Old Apr 2, 2012 | 06:49 PM
kux03's Avatar
5th Gear
I used a PAC SOEM unit this past weekend on my install- required with a bose system like the one in the '03 CL with a factory amp. Two quick tips if you use this unit. 1. It is completely passive, which means that you do not hook up the power, ground, or remote wires that come out of the output side of the device. You only need to connect the speakers wires through the device and then all of the other wires connect directly from the aftermarket harness to the factory harness. 2) make sure you do not bump the speaker volume adjustment knobs when wiring up the device.- will screw with your sound
The unit is pretty bulky but I didn't have a problem with fitting it behind my new double din in my '03 CL.
Old Apr 6, 2012 | 12:37 PM
BoricuaTL's Avatar
05 WDP 6MT
make sure you connect the blue/white stripe wire coming out of the pioneer unit to the same color wire on your harness
Old Apr 20, 2012 | 02:09 PM
FwC's Avatar
FwC
Did you bypass the factory amp? #7 on the link is where the amp is located behind the trunk lining on the passenger side.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Old Sep 18, 2012 | 08:31 PM
BFHK's Avatar
4th Gear
Here't the method for bypassing the factory amp.
https://acurazine.com/forums/audio-video-electronics-navigation-22/how-bypass-factory-bose-amplifier-869018/
AndrewS
19
Mar 14, 2024 06:59 PM
Feb 25, 2020 09:57 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
acurajj
Sep 19, 2015 03:47 PM
trinikidcl
Sep 4, 2015 12:56 AM
