install questions
Old Oct 30, 2003 | 04:37 PM
oapy123's Avatar
install questions
about to do an install on 2001 cl type-s and i need to know how you all did your installs, its gonna be one 12" IDMAX, and a jbl 1200.1.
How did you run your power wire?
Where did you get through the firewall?
How do i access the rear speakers so i can use a l.o.c.?
Where can i ground the amp? Where can i mount the amp?
the box is going on the left side of the trunk facing the middle, is that going to sound alright?
the reason i'm not putting the sub under the navi facing the back is that there is not enough clearance to fit the sub box under it. If anybody has put their sub like this please let me know how you fit it under the navi...btw i will be making my own box so if you have measurements that would be awesome...box needs to be around 1.50 cu.ft. before displacement.
any other helpful hints would be awesome.
hues10
1G RDX (2007-2012)
Sep 7, 2016 03:47 PM
Skirmich
Sep 15, 2015 06:41 PM
datadr
Sep 12, 2015 09:12 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
