INFINITY PERFECT 6.1 in REAR speakers
ok...my friend who knows ALOT about cars who has 94 integra all fixed up ...has infinity kappa 5.1 front and rear ..i wuz talking to him and asked him u think infinity kappas 963.5i 6x9 speakers would be ok? and he said juss get infinity kappa 6.1 and make it fit in the back
IS THAT POSSIBLE~
cuz this guy does know ALOT of cars
he installed his speakers by him self and does everything himself
IS THAT POSSIBLE~
Commander in Chief
Yes, it's possible. Is the 6.1 a component set? If so you would need to make a filler plate to mount under the rear shelf to hold both the tweeter and the woofer. Also you can't allow any sound from the rear of the speaker, mix with the front this causes distortion, so make sure when you build the plate there are no big gaps around the speaker and no open holes around the outside of the filler plate.
Yeehaw
Its possible sure but no real reason to do that unless you are getting the speakers for real cheap or something. In a 2 door you don't need components in the rear, the fronts should do the job just fine IMO.
so should i juss get infinity perfect 6.1 for front speakers and infinity kappa 693.5i 6x9 3 way speaker for my rear?
would that be better then both front and rear being 6.1?
or i mean there is no need to put 6.1 for rear and front?
THX
i will juss get 6.1 and 693.5i for the rear speakers..
one more question...when i get the tweeters from my component 6.1 speakers...should i put those tweeters way infront left and right where there is my stock tweeters or should i put them next to door opening thinggy?
i have 98 2.3 CL
i have 98 2.3 CL
Yeehaw
Personally, I would put them in the stock location just so you don't have to cut holes or have extra shit sticking out of your car. Technically there may be a little bit better spot to put them but I doubt you would be able to tell the difference. I would angle mount them in the stock location facing towards the seats.
sockr1
10-01-2015 01:31 AM
ivegotthenav
09-11-2015 07:51 PM
