InConsistent Bass Level
Old Feb 14, 2005 | 01:19 PM
dark inspire's Avatar
El Presidente
Unhappy InConsistent Bass Level
I noticed that the bass in my car is way louder when the car is at a standstill versus when i have my foot on the accelerator pedal. Is this normal? The minute i take my foot off the pedal the volume of the bass goes up. Do I need another battery or a capacitor or something? thanks!
Old Feb 14, 2005 | 01:38 PM
elduderino's Avatar
VP Electricity
Typically your alternator would be holding the electrical system at a higher voltage when revving than when idling... so if your bass were going away when you took your foot off the pedal, that might indicate a voltage problem.
But bass getting louder when idling...the only theory I have is that the modified exhaust note and the louder modified air intake just drown out the bass.
Old Feb 14, 2005 | 01:41 PM
El Presidente
hmmm maybe im just paranoid or something and there's really nothing wrong, but that could be the case. It is possible its just the roadnoise and what not. Is there anyways to test this?
Old Feb 14, 2005 | 01:46 PM
elduderino's Avatar
VP Electricity
The only thing I can think of is to try an RTA analyzer, but even then, when I test the stock TSX exhaust most of the noise is in the bass, so that's what would interfere with your bass the most.
Old Feb 14, 2005 | 01:52 PM
El Presidente
oh ok, i think the TSX has a more apparent exhaust note compared to my 2nd Gen TL, atleast thats what i noticed when i got a TSX loaner. Maybe its just me, but i will keep listening and have my friends listen as well.
Old Feb 14, 2005 | 01:54 PM
elduderino's Avatar
VP Electricity
I would think your removed airbox would be noisy...
Old Feb 14, 2005 | 04:46 PM
El Presidente
its prettymuch stock sounding, unless a floor it, which i dont do to often. I played some different CD's on the way back and forth from school, and there is definately and undulation of volume.
Old Feb 14, 2005 | 06:41 PM
elduderino's Avatar
VP Electricity
OK, I can't remember but I think you have a stock HU. Run a long RCA cable into the amp, and get your trusty discman out again : )
If you have the same issue with the discman, it's the amp. If you don't, it's some sort of EQ/compression in the HU signal output.
Old Feb 14, 2005 | 06:45 PM
El Presidente
back to that again! well i was driving on the freeway and it seemed fine, i think it was only during city driving that it would dip in volume. looks like another weekend to rip apart the system
Old Feb 14, 2005 | 07:21 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Dang...it's messed up again man?
It only happens on the bass?
where did you ground the amp?
Old Feb 14, 2005 | 07:23 PM
El Presidente
yeah man, its not too noticeable, but enough to drive me nuts i grounded it above the trunk hinge. i sanded the hell out of the spot and used the grounding block, i dont think its the ground, but knowin' my luck, im gonna buy some high quality RCA's when i get a chance, im still usin the home ones
Old Feb 14, 2005 | 07:31 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Oh okay dude...yeah hopefully that helps. I can still check it out sometime if you have trouble man. Switching out the RCAs is a good first step.
Good luck bro!
Old Feb 14, 2005 | 07:36 PM
El Presidente
Good luck bro!
yeah man, lookin forward to next weekend, got a 4-day weekend, so i should have time to mess with everything. btw, which brand RCA's would you guys recommend, i originally had the 20-buck monster cables, but i think i need to put a lil more money in them.
Old Feb 14, 2005 | 07:45 PM
elduderino's Avatar
VP Electricity
The single biggest waste of money when I was in retail was getting people to spend more money on RCAs because they would get better sound or more bass or less noise (this was before twisted pair). I can't tell you how many times I took OUT a set of expensive RCA's and substituted cheap black crap and noise went away.
The three things I tell people to spend money on with an RCA:
1) Twisted pair. For noise rejection. For bass amps it's not worth it - if your woofer can play engine noise, you have a LOT of engine noise.
2) cast outer barrel. Lasts longer. Not an audible diff to me but better connection over time.
3) split center pin. See #2 above.
Thicker insulation is nice, but unless you're bending them hard or pinching them it's really not a deal. I have a friend used to work for Alpine who made his own Kimber Kable knockoff RCAs for his cars,with no shielding and no outer jacket insulation, all twisted conductors. The jacket is just to protect from damage as they are being pulled by the American Tourister gorilla-installer.
Old Feb 14, 2005 | 07:47 PM
El Presidente
yeah i had a feeling about that...no problem, more money for the headunit!
Old Feb 16, 2005 | 05:27 PM
El Presidente
im not sure exacty what caused the problem, but it doesnt seem to be happening any more (probably just paranoia)! As far as RCA's are concerned, just about any will do im guessing.
Old Feb 16, 2005 | 05:33 PM
El Presidente
while we are chattin about wires: does the same apply to speaker wire from the amp to the sub? does a thicker wire have any benefits?
spoiler900
Oct 10, 2015 06:48 PM
Houston
Oct 8, 2015 01:27 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
steve
Sep 30, 2015 09:23 PM
kb1rl
Sep 30, 2015 10:17 AM
