Improving the Audio System
Old Aug 28, 2001 | 09:32 AM
jbn's Avatar
jbn
Question Improving the Audio System
Hello All,
I want to step up the audio system in my TL-s. I'm not looking for booming bass, but just good clear sound without distoriton. Should look to change out some of the speakers, all of the speakers, the deck. Let me know what you think is the best way to go.
Thanks in advance.
Later
Old Aug 28, 2001 | 09:53 AM
http://www.acura-tl.com/forum/showth...111#post167111
Check out this thread. djsteve talks about replacing the speakers. It's in his first response near the end.
Old Aug 28, 2001 | 09:56 AM
juniorbean's Avatar
Lightbulb
What I did on my CL (and will probably move over to my TL) was add two Bazooka base tubes in the trunk. One with the built in amp, which powered the other. I had them hooked up to a switch so I could turn them on and off as desired. They weren't that big (6 1/2" woofer in each tube) they weren't expensive (less then $300 installed for both), they were pretty easy to install (a family friend did it for $25) and they added a good amount of bass without that booming bass sound!!
Old Aug 28, 2001 | 01:54 PM
asiankidd's Avatar
hey junior bean, can you find out where you family friend taped in for the sub signal....i heard there were problems with getting a low level line input that was clean.....how is yours wired?
Old Aug 28, 2001 | 02:22 PM
hemants's Avatar
Turn your bass all the way to zero and turn the treble to about 1/4.
The problem with Bose systems and especially the one in the TL is that they are sorely lacking in midrange and the crossover point for the sub is too high (around 200Hz). It needs to be below 80 Hz to be omnidirectional.
It's not a real solution but it helps in the meantime.
Old Aug 28, 2001 | 02:35 PM
juniorbean's Avatar
Originally posted by asiankidd
hey juniorbean, can you find out where you family friend taped in for the sub signal....i heard there were problems with getting a low level line input that was clean.....how is yours wired?
Honestly, I'm not sure how it was wired, I'd have to find out for you. I'm pretty sure he used some line convertors on the install. I'll have to find out.....
Old Aug 28, 2001 | 04:23 PM
SoundSpeed's Avatar
This is a good thread, but I will put it in the audio section.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
Cgannotti
Sep 25, 2015 05:04 PM
