MISC: impedance/wiring question..
Old Dec 7, 2009 | 12:23 AM
  #41
BIGBOOMER77's Avatar
Socal
Originally Posted by eggyhustles
the 10" is 99
Don't let the 300w rating fool you..it's all about being efficiency
I don't know of any other woofer for 120..rsdc is better, but cost more. sundown e8's are discontinued...
anyone else?
really? it was a toss up between the rsdc and the orion... i chose the orion... i can find the rsdc for 100
Old Dec 7, 2009 | 12:24 AM
  #42
eggyhustles's Avatar
go for the rsdc then
Old Dec 7, 2009 | 12:31 AM
  #43
Socal
why? ive asked a few people and the results are torn..mixed answers
Old Dec 7, 2009 | 12:37 AM
  #44
mattastick's Avatar
Sorry Brian, I haven't been on the computer since Friday.
OP, here's what I'd do. Since you're gonna be running a sealed box, that will help the suspension of the sub to handle a bit more power. That is, if the coil can dissipate the heat, and everything else in the sub is up to par. Since you said that's the enclosure that the manufacturer suggests, you should be alright to run rated power or a bit more. Now, the old school Orions were beasts, the new ones, not so much... Just keep that in mind...
Now, another disadvantage that most people are forgetting is the fact that an amp is less efficient at lower ohm loads. So if your amp is somewhere around 80% efficient at 4 ohms (which I doubt it is), when you drop to 2 ohms, or even 1 ohm if you want to do that, you're going to have a decent little drop in efficency. I'm pretty sure my Sundown is like 80-85% efficient at 4 ohms, and something like 60-65% efficient at 1 ohm...
The real way to set your gains (in an ideal world) would be using a DMM, clamp, and an O-Scope. This way, you could use the O-scope to find where the signal starts to clip, and the clamp to figure out exactly what kind of power output you're getting. At the same time, you can use the O-scope to know exactly where your head unit starts to send a clipped signal to the amp(s). Then you'll know where you can't turn your hu up past. Now, unfortunately, you can't exactly use music to do this type of work. Unfortunately, you'll have to use some type of test tone. So to counteract this, you'd have to check at several different frequencies for a daily setup. If it were for a pure SPL setup that's only going to play 1 note, then you don't have to worry about inconsistencies due to frequency change. You're also unable to account for any clipping in the input signal. This would include things like clipping in the actual recorded track itself, or if someone has altered the music in any way, then it could have clipping in it, which the test tone wouldn't. The way around this is to use either a -3 or 0db tone. Most music only gets to -10 - -20 db, so you should be ok.
Old Dec 7, 2009 | 12:53 AM
  #45
I usually just do it by ear lol
Old Dec 7, 2009 | 12:55 AM
  #46
Socal
pretty informative man...how about the amp/sub combo at 4ohm i should be good right?
and so you dont have to flip back
sub is orion xtrpro102, amp is performance teknique icbm-896
Old Dec 7, 2009 | 01:05 AM
  #47
mattastick's Avatar
Never used them, can't say...
But the IA 187 is supposed to be a very solid sub. There were guys using them in DB Drag's lowest class (Street Stock) which allows for 2000w on 1 15, 2 12s, or a couple other sub combinations. I'm pretty sure the current record car is running 2 12s... So keep that in mind when you're looking at power ratings... I'm not suggesting you do that by any means, not until you've got the experience that some of those competitors have...
Old Dec 7, 2009 | 01:15 AM
  #48
Socal
i meant power wise...the specs are on the first page..but if i had money to compete..i would do sq....i used to be an spl nut when my brother had his re xxx back in the day(2000w rms beast) weighs 70 lbs or something... bigger then most 8 yr olds lol. now im more sq orientated but still want something nice n loud
Old Dec 7, 2009 | 04:32 AM
  #49
so save up for an idq, or fi q..
Old Dec 10, 2009 | 01:36 PM
  #50
n0rm's Avatar
I ♡ PEK PEK
A new amp and a sub won't do you any good if you're getting a lot of distortion from your source unit.
Old Dec 11, 2009 | 08:32 PM
  #51
duyx817's Avatar
DFW AREA,
1 ohm per channel here! they sound good.. its more about distortion then sq. but with type r's they cover up the dirty sounds
Old Dec 12, 2009 | 02:21 AM
  #52
Socal
seriously...wtf norm....
Old Dec 14, 2009 | 10:26 PM
  #53
n0rm's Avatar
I ♡ PEK PEK
^ You can put Martin Logans and McIntosh amps in your car but if the source is distorted, GUESS WHAT HAPPENS?!
I keep telling you to fix something else besides your sub but you don't seem to like to listen. You call me a hater when I told you your amp sucks but deep inside you knew that when you posted this:
Originally Posted by BIGBOOMER77
my amp is.... with reluctancy lol : Nitro bmwx-482,and the other is performance teknique icbm-896
I can sugarcoat it for you and tell you that your system sounds clean but what is that going to do for you? Stop going by specs alone and look for a quality brand. Stop going to the swap meet to buy your stereo equipment.
Old Dec 14, 2009 | 11:49 PM
  #54
on1wheel01's Avatar
+1zzz
kosstick
Dating & Relationships
70
Aug 28, 2008 11:48 AM
jose416
Mar 29, 2008 02:21 PM
Shoshinsha_KiDs_CL
1G CL Problems & Fixes
26
Nov 17, 2007 10:48 AM
Code_25
Jul 19, 2007 07:34 PM
nippon_wa
Dec 13, 2004 10:37 AM
