ICE Link works when COLD!?!
Old Oct 30, 2006 | 04:36 PM
mattster's Avatar
Driven to Perfection
I installed a Dension Ice-Link last spring in my 04 TSX Navi. I bought the required Y-cable (not sure what kind now), but I get sound out of the ipod just fine. However, it's always made my Navi run slow or become unresponsive. I noticed recently that it seems to be associated with - believe it or not - the temperature. On a hot day, my navi is unresponsive (touch screen, voice, everything). On cool mornings everything runs smooth as butter. I have been testing my theory by setting the A/C to LO to see if i can get a quicker response, and sure enough, it works.
I'm not sure how the ice-link works, but I think it must pass-through the signals going from the touchscreen and button controls through to the HU, and I'm thinking the delays / unresponsiveness are due to some sort of process that goes on inside the Ice-link. And for whatever reason, the system runs better when cold (actually makes sense when you think about it... this is why our processors have heat sinks, fans, and etc - they just don't run well too hot.)
So my question:
How do I fix this?
-Change the install location: currently the ice-link unit is in the center storage area, basically under the cup holders - and the cable runs into the center console armrest. Is there a better (cooler) location? Where do you other ice-linkers have it installed?
-install a liquid cooling system? (kidding)
-call dension and hope they'll help me out?
-other suggestions?
has anyone else experienced this problem? I'm glad to at least have found some cause... for me ipod > navi (most of the time) but it sucks to have to choose.
Old Oct 30, 2006 | 06:29 PM
elduderino's Avatar
VP Electricity
Don't try to work around this - I see it as an incipient failure mode.
It's not a pass-through per se... but it IS a node on the network.
I think that the micro on the Icelink board is messing up the transmission. THey seem to run hot and the heatshrink on the top doesn't help.
DICE/Dension USA will upgrade your Icelink to a new DICE module for $50, if memory serves.
If it still has the problem, at least DICE units are more marketable.
Old Oct 30, 2006 | 07:26 PM
mattster's Avatar
Wow. that's good news. I was actually looking at the DICE unit today as well. Do you know if I can use the same Y-cable? (I believe I have the P.I.E. harness)
What are the functionality differences between the Ice-Link Plus and the Dice?
Also, I see they have a new cradle with video out capabilities. I wasn't able to determine whether it is available yet, but I'd be interested in pairing that with Dom's unit... has anyone done that yet?
Old Oct 30, 2006 | 07:39 PM
elduderino's Avatar
VP Electricity
The wiring connections are identical.
The DICE will let you change tracks like the Icelink. The iPod controls are always enabled.
If you select disc 2 using the disc up/down keys, then the next/previous keys that were controlling tracks, change playlists. Disc 3, change Albums or Artists, I can't remember. Disc 4, change chapters if you have something with them, and Disc 5, change to the aux input on the DICE unit.
I would do the video interface if it weren't such a great way to get in an accident.
Old Oct 30, 2006 | 07:51 PM
mattster's Avatar
I've heard about some compatability issues between the new 80 gig video and the Ice-Link. Does the DICE have any issues?
Also, do you know anything about DICE's HD Radio tuner?
acurajj
Sep 19, 2015 03:47 PM
ivegotthenav
Sep 11, 2015 07:51 PM
theinsvnity
Sep 10, 2015 10:22 PM
dlknight
Sep 3, 2015 07:54 PM
