I need help!!!!
Old Mar 31, 2003 | 07:59 AM
Red-CL's Avatar
Doin' da crack shuffle
I need help!!!!
I recently came across an 15" Eclipse sub pretty cheap so I had to buy it. The problem is that I want to make ( or have one made) a sealed or ported enclosure for this sub. Of all the trunk setups I've seen on here, nobody has ever used an 15" sub. I need ideas. I don't know what to do!
Old Mar 31, 2003 | 09:36 AM
Nicky Pass's Avatar
Fuct in the hed!
I hope you plan on NOT having any trunk space!!
Old Mar 31, 2003 | 09:49 AM
fuzzy02CLS's Avatar
Get a box made to fit the trunk lines. It's going to be a BIG box though. You could get it made the width of the trunk between the wheel wells, & as high as the rear deck. You might have enough room to still acces the spare. Have a shop run the specs of that sub, & see how big of a box is needed.
You will need a monster amp to power an 18 too. Mono 500W RMS at least.
Old Mar 31, 2003 | 10:45 AM
Red-CL's Avatar
I stand corrected!
It's a 15" Sub!
Old Mar 31, 2003 | 06:56 PM
ricardo's Avatar
lol... big diff, hehe
side note... what do we prefer: eclipse or JL 10w3?
that is for getting just a single 10
Old Apr 1, 2003 | 03:51 AM
autophile1's Avatar
Re: I need help!!!!
What model is the sub? Eclipse makes three different models of 15" subs...
Bryan
Originally posted by Red-CL
I recently came across an 18" Eclipse sub pretty cheap so I had to buy it. The problem is that I want to make ( or have one made) a sealed or ported enclosure for this sub. Of all the trunk setups I've seen on here, nobody has ever used an 18" sub. I need ideas. I don't know what to do!
Old Apr 1, 2003 | 07:44 AM
Red-CL's Avatar
Re: Re: I need help!!!!
Bryan
It's a 15" sub and the model is 87151.4. I figured one 15" sub in a sealed or ported box would save me more space than using two 12" subs in a bandpass box.
Here's the link!
http://www.eclipse-web.com/products/...dvc.html#87151
Old Apr 2, 2003 | 11:36 PM
Ant7701's Avatar
Sweet as Gold
My friend had two rockford 18" subs in the back of his maxima . No trunk space at all . However the Rockfords only took 200 watts max , 100 watts rms . The shit pounded though . Broke the trunk springs in his car cause the subs had to be facing up to fit .
