i did a bad amp wiring setup..help
Khmer Pride
after i finish the sub..i bought the car to stealership..and everythign was complete..they also check my wiring for my amps..after i pick it up..they also call me up saying my amp wiring is incorrect..also my pop told me that i wire it wrong too. but now i got click click and its not the starter motor..my battery is drain because the amp is still on and while the car is still off. so wat do i need to make it not take up my battery?
Capacitor..or i got find a way to set it up correctly
Just chillen..
If you are on stock headunit, you need to run the remote wire to the fuse box onto a fuse. So when the the car's keys are out, everything is turned off. Get it? Now I have a 99TL, so I wouldnt know which fuse to run it, so check that out, I believe is 12V.
Honda/Acura pimp
connect the remote to the blue wire in the harness for the aftermarket hu and that should turn the amp off/on with hu
another thing to take into consideration is your battery/alt
there could be a dead cell in your batt
if so alt cant fully charge batt and the amp is stealing current from batt that will result in a no start condition
ive seen this problem more in rsx's tho with dead cells in batts so make sure that every charging component is up to par and if so start wangin
also that cap wont do anythin but create more of a strain on your charging system if u need more current invest in an ho alt
Seems to me like a Remote wiring problem, you can just find another place to put the remote wire. I had my amp and sub installed professionally with the stock headunit and that's what they did.
Loose Cannon
Originally Posted by Jonesi
I can't even comprehend... Bad english makes it harder to help and understand what you are talking about..
OH SNAP...............................
InFaMouSLink
10-30-2015 09:43 AM
SUPRMN84
10-07-2015 09:46 PM
