How to wire this...?
Old Jun 6, 2002 | 12:03 AM
hornyleprechaun's Avatar
Bent = #1
Ok basically I'm wiring 0 guage wire from my battery to my trunk...then after that I plan on using a fuse distribution block just like http://www.sounddomain.com/sku/PHOZBB34 ...then I'll run the 4 guage wire to my 2-3 amps...if this sounds correct so far...where would I put the 2 capacitors in that wire? before the distribution block or after? Also would just one 0 guage wire be enough because that distribution block can handle 3 0 guage wire inputs? thanks..
bow: CL'S
Old Jun 6, 2002 | 01:03 AM
Woodsdaddy's Avatar
Everybody Wang Chung
How many amps are you planning on using that you would need more than one 0 gauge cable? Also how much power do you think you will need to power them?
Old Jun 6, 2002 | 09:18 AM
SilverKnight's Avatar
Retired. Not available.
Re: How to wire this...?
bow: CL'S
You wanna put the CAP(s) as close (min. wire length) to the amp as possible.
Old Jun 6, 2002 | 11:43 AM
Bent = #1
I'll have 2 amps and then maybe I plan on adding another 1....one of them will be 800 watts...the 2nd one will be 400-500 watts...
CL'S
Bent = #1
Re: Re: How to wire this...?
Aight thanks a lot man...
CL'S
Old Jun 6, 2002 | 12:04 PM
Woodsdaddy's Avatar
If you look in the manual of the amps it should tell you how many amps it pulls, that would tell you what size cable you need. I don't think you will even need a second cable unless you are running over 150 amps.
Acura604
20
Aug 5, 2017 12:55 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
