how too head rest TV's
Old Nov 8, 2004 | 01:14 PM
Stokeless_TSX's Avatar
Stokeless
ok its been a while so if i miss a step...DEAL WITH IT haha. OK first things first find TV's that will fit your head rests. I used 5.6 in XO vision TFT screens.
1. Remove the headrest from the seat and take it out. If you dont you will have a hell of a time doing this.
2. Take the screen itself with no bracket or mounting kits and line it up on the headrest. Mark with pencil or something that will wipe off the corners.
3. Take a ruler and find the center point from all the corners of the screen on the headrest. use a razor blade and cut the head rest in an "X" from corner to corner and then pull out the stuffing. Not too much just enough to fit the screen in.
4. This is the tricky part on the XO vision screens the mounting bracket had a lip that was on it. to get it to fit i had to grind it off. Place the bracket inside the headrest. If it is not centered or have enough support place some of the stuffing back in behind it and under it to support it.place the leather inside the brackedget a glue gun or epoxy and glue down the leather JUST ON THE INNER LIP OF THE BRACKET. Then use the razor and cut off the excess. You have to make sure you run the wires down through the headrest befor you place the screen in there or you are gonna have a hard time pulling the screen out.
5. To get the screen in you will have to force fit it. It will never come out haha. Have fun any questions feel free to msg me.
Stoke
Old Nov 8, 2004 | 01:20 PM
elduderino's Avatar
VP Electricity
Old Nov 8, 2004 | 01:40 PM
I10O0I1's Avatar
Team Nighthawk Member
thanks alot stokeless... u really came through for me.. thanks alot man.. when i have the money to afford the tv i would be doing this mod myself... hopefully i dont mess anything up..... question when i buy the tv the bracket should be included with the tvs correct?
equiptment needed
razor blade
glue gun
tv
Old Nov 8, 2004 | 02:26 PM
tsass's Avatar
INFORMATION ARCHITECT
so i will add some click on the link then click on the headrest screens link
Old Nov 8, 2004 | 05:15 PM
I10O0I1's Avatar
question how would they wires go through... do i hide it in the seat.. it should go from under the hearest to the seat correct ? and after that ?
Old Nov 8, 2004 | 07:11 PM
elduderino's Avatar
VP Electricity
OK, thanks fr the pics. Some points:
1) The TSX HR is narrower than yours. I don't think your info is applicable to the TSX. I think the screens would have to be too small, and like yours, not wide-screen (4:3 instead of 16:9).
Somebody posted here with a TSX a while back and used the gray leather HR from the family Caravan, since it matched and was wide enough for a monitor. I bet that you could order HR from some other car, that still matched, using the Vizualogic or SAAV or other HR program.
2) The HR you are using protrude a lot, and the bucket seems to have a sharp corner. Audiovox, Directed, and Rosen all offer a 7" widepanel with a much more flush bucket and panel mount, without the sharp corner, and with a nicer flange. I would suggest looking at that one if you are going with a bigger headrest.
Here's a picture:
http://www.rosenentertainment.com/ro...ors-UN7000.htm
Old Nov 8, 2004 | 07:19 PM
elduderino's Avatar
VP Electricity
OK, I found what I was looking for. Check this out: http://www.kponeinc.com/netclick/tsx/
Old Nov 8, 2004 | 07:29 PM
I10O0I1's Avatar
good find... thanks man
Old Nov 9, 2004 | 10:46 AM
Stokeless
if you want pix of the screens go look in the gallery i have some in there just search for me. I still need to take more. Run the wires down the headrest and into the seat where the headrest slides into you can pull the leather out a lil bit and run the wires down. Take the plastic off the back of the seats and you can run the wires easily. If you dont take the plastic off you will have a hell of a time doing it. Hope this helps.
Stoke
Old Nov 9, 2004 | 11:49 AM
I10O0I1's Avatar
um are you talking about the hole that slide the pole for the headrest in? and then pull the back cover off and after that where does the wires go? i think pics will be great hehe.. maybe i can help with pics if u need help..
Old Nov 9, 2004 | 12:38 PM
elduderino's Avatar
VP Electricity
No, he's talking about pulling the leather away from the plastic HR trim ring so there is room for the wires to go inside.
If you look at the inside of the outboard trim ring I think you can see his wires:
Old Nov 9, 2004 | 12:39 PM
elduderino's Avatar
VP Electricity
If you try this remember to heat the material a bit with a blow dryer to make it more flexible, esp. in cold weather... but not too much, don't want to stretch it and ge wrinkles!
Old Nov 9, 2004 | 01:14 PM
DrunknMonkeY's Avatar
3rd Gear
just a heads up if you want a wider screen get 04 accord headrests they fit in the tsx seats but are a little wider than the tsx's
Old Nov 9, 2004 | 03:01 PM
elduderino's Avatar
VP Electricity
Pic of Vizualogic 04 Accord preinstall product:
http://www.vizualogic.com/common_products/headrests/models/honda_accord.html#accord_2003
MSRP is $1400 per pair of 7" screens in headrests. Plug and play.
Let the complaining begin : )
Old Nov 9, 2004 | 05:50 PM
tsass's Avatar
I took this picture befor the job was finished so the back of the seat is still off. if you look at the bottom of the pic you can see that.
the tubes that hold up the headrest are solid so there is no choice but to run them on the side. as long as the head rest is down you can not see them.
This is a CL so the tsx might be different not sure do not rember
Old Nov 12, 2004 | 01:27 PM
AZTSX's Avatar
Does anyone know the maximum housing dimensions also stoke your using ur ps2 for the dvd player correct? i am thinking if i can do that with an xbox but i want it to be clean. I am looking to do this all within the $800 range. Is this feasible
Old Nov 14, 2004 | 02:07 AM
Stokeless
Yes it is feasible. If you do it your self. I got my screens for a hook up price...and I already had the PS2. You will need a distribution box for th RCA's from the xbox to the screens also a power converter. I have my in my arm rest. Ran all the wires under the carpet and have the PS2 mounted in the rear seat armrest. So when it folds down there is my PS2. Good luck. alos will need a FM modulator or a SNhond3. I am using an FM modulator becuase im dreading pulling the dash apart again...it sucks.
Old Nov 14, 2004 | 02:16 PM
AZTSX's Avatar
PMed you stoke
Old Nov 15, 2004 | 04:26 PM
Stokeless
ok i replied.
Old Nov 15, 2004 | 04:30 PM
iamhomin's Avatar
04 remembrance
Pointless luxury.
I want it!
Old Nov 15, 2004 | 04:37 PM
Stokeless
it looks nice at night rollin past the clubs hahaha
Old Feb 12, 2005 | 02:28 PM
NFLblitze1's Avatar
Youse Gots Sacked
adding the actual headrest isn't the hard part....i think the wiring is the hardest part
Old Feb 13, 2005 | 10:17 AM
Stokeless
Your right the wiring is the hardest part running it under the carpet and under the rear seat to the back of the PS2 ...cut my self a few times.
Old Feb 13, 2005 | 10:38 AM
NFLblitze1's Avatar
Youse Gots Sacked
splicing wires and setting things up, running it through the actual headrest poles etc...its not easy, the wiring is probably the most undesirable part
mlody
Dec 4, 2019 02:11 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
Oakroadsteve
Oct 28, 2015 10:28 PM
Jimmy_D
Oct 7, 2015 11:52 PM
Eggs999bacon
Sep 24, 2015 10:08 AM
