How to set the subs ohm?
Autobot
How do I set the ohm rating on the sub from 4-ohm to 2-ohm? My amp is a kenwood 1000w (KAC-929) but has 150w x 2 @ 4-ohm RMS. I use 2 infinity reference 12" (300w RMS each) and my amp can't power both. My friend told me that if I can get the subs to 2 ohms each, I can get both to power fine. Right now I bridge the amp to get 460w RMS to one sub. The amp is rated at 230w x 2 @ 2-ohm, would that be enougH? Or would I be better off to just buy another amp and sell this one. Thanks in advance
Autobot
how do I wire the subs in parallel? I was thinking of a stronger amp too
-EDIT-
You mean like, how the power is bridged, just put both speaker wires into the + and - that are bridged? then send both of those to the 2 subs?
-EDIT-
