How to put stock stereo back in?
I've read the post before about how to find code when putting the stock (boss) radio back in. But I can't find that post anymore..
Can anyone help how to find the code?
It's usually on a card with your owner's manual. If not, you should be able to call the Acura dealer with your VIN and they can give it to you. They might require the serial number off of the radio so you might want to write it down while you have it out.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
You can either find it under the fuse box cover, or along side the inisde of the dash next to the glove box
My buddy that is a tech for Acura told me that you can also get the serial number with the radio in the car. Make sure the power to the radio is on but have the radio off. Then press 1 and 6 buttons simultaneously for a few seconds and the radio serial number will flash across the screen.
Anyone know how the code looks like? How many digits it is?
If I find the numbers from fuse box, or globe, do I just turn on or off the radio and push those code? that's it??
Cuz I found some numbers 5-6 digit behind coindrawer but that didn't work..
(Mid-Atlantic)
(Mid-Atlantic)
yup, should be a 6 digit code
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
