How Much Power Wire
Old Apr 30, 2005 | 01:52 PM
Doc Holliday's Avatar
Question How Much Power Wire
In our 2nd Gen TL's
I'm replacing the factory stereo...
Should I just buy a 2 amp kit and be done with it?
Or what length of power wire, speaker wire, ground wire should I get?
Will this work
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5769406148
or this
http://www.walmart.com/catalog/searc...&Continue=Find
Old Apr 30, 2005 | 04:14 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Go with the stinger, or something similar, the walmart kit is pretty shitty. I bought like 3 of those scoshe sets, and don't use any of the parts from them now. I have redone my power so many times. I would get the stinger, rockford fosgate, or lightning audio. Stay away from the walmart specials. That stinger set looks good. How many watts you trying to push, and one amp or 2?
Old Apr 30, 2005 | 04:15 PM
(Mid-Atlantic)
That stinger is a good 2 amp kit, it has the distribution block for the 2 8-gauges, you should be set.
Old Apr 30, 2005 | 07:04 PM
dark inspire's Avatar
El Presidente
yeah man, get the Stinger Kit, ive had good luck w/that brand so far
Old Apr 30, 2005 | 07:48 PM
big mike 13's Avatar
the amp kit i got... the power wire was a bit short (just reached my trunk, by a foot, and the engine bay is pretty damn tight)... and i think it came with 20'
so i think like 25' would be good, you can always cut it.
Old Apr 30, 2005 | 07:59 PM
Question
I'm running 2 amps and I will mount them upside down under the rear deck just like the NAVI system.
One amp is 300 watts and the other is 421 to my subs.
Check this kit out and tell me what you think... This guy wants to sell it to me shipped for $55
http://www.lightningaudio.com/2004/p...asp?prodID=389
I just want to make sure that the wires are long enough... Mike said his was too short and that I should get 25 feet!?... Did everyone have this problem? and if not, is this kit good to go even w my two amps.
Going from left to right... NAVI, Amp 1, Maybe Cap, Amp 2... all on the rear deck in the trunk.
Old Apr 30, 2005 | 08:24 PM
optomos's Avatar
I=X - optomos
You should have more than 17/18 feet of power wire. If you want a cap then get this kit: http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
It also has 22 feet of power wire. If you want to save $ you could go to any place that sells welding supplies and buy power cable cheap.
Old Apr 30, 2005 | 08:43 PM
Question
Now that's what I call a kit !
I think it's too much for my system though... my system is only running at 700 watts total... and if I use a cap it will be between the fused block and the amp to the subs right?
I saw the power wire at Home Depot... Is that 4 guage okay to use for this application? Is it insulated enough or is there any difference?
Old May 1, 2005 | 12:45 AM
El Presidente
Caution while buying that kit!!!!
I bought that for a friend of mine, and let me tell you, it might be 4-Gauge but it as WAY less strands of wire than the regular Stinger HPM 4-Gauge wire. So becarefull and just get the regular kit IMO.
Old May 1, 2005 | 02:01 AM
Lightbulb I've Narrowed it down
I think I'm going to rock this kit...
or this one
http://www.cardomain.com/item/ROCCP4DCKS
Let me know which one you like or what you think
I hear that I'll have to still get diff RCA's with both of these cause the one's in the RF kit suck.
Old May 1, 2005 | 06:15 PM
DerrickM's Avatar
Exclamation
Hi. You should NEVER mount an amp upside down, unless the manufacturer specifically states that it's okay. (Allows the heat to buildup inside the amp).
Old May 1, 2005 | 06:17 PM
DerrickM's Avatar
ps - what kind of fish is that in the picture?
Old May 1, 2005 | 07:17 PM
Red face Lol
Commonly known as the lawnmower Blenny... He's cool... These type of fish use their lower jaws like shovels and then the sand comes out through their gills all day... It's fun to watch and it sifts the sand around for the good bacteria to flourish in the sand... the live sand
http://www.liveaquaria.com/product/p....cfm?pCatId=94
Old May 1, 2005 | 07:19 PM
Angry Damn... Foiled Again !!
Wow.. I didn't think about that... shit, now i'll have to find some kind of bracket like the navi has. arrrgh.. pain in the ass
I didn't want to mount anything on the box.
Old May 1, 2005 | 07:22 PM
El Presidente
you could build an amp rack and have it mounted vertically agains the back seat.
Old May 1, 2005 | 07:35 PM
I'm not handy man... or handyman.
That sucks, are yall sure I can't mount them biatches upside down? 300 watt sony with a fan and an MTX 421d.
Old May 1, 2005 | 08:17 PM
El Presidente
do you need all your trunkspace? you could mount them flat on the ground near the back seat and have the wires running underneath the floormat
Old May 1, 2005 | 10:13 PM
I want to just use up the small back part of my trunk... and I was just going to put everything next to my Navi... cause it's taking up the space anyways... I need some kind of a rear deck bracket like the one the Navi rests on... then I'll be set
Old May 1, 2005 | 10:14 PM
optomos's Avatar
I=X - optomos
or this one
You can also use Tsunami, JL, or Streetwires kits to. Between the 2 you choose I would go with stinger.
Old May 1, 2005 | 10:22 PM
DerrickM's Avatar
I like to build a shelf that hangs down from the rear deck (package shelf). It's a chore, but not too bad. Cope a couple 2x6's to fit, then drill three holes through each and through the shelf (with everything removed from the top of it of course). Then use 1/4" bolts from Home Depot, and construction adhesive like Liquid Nails to keep the thing from ever squeaking or vibrating). Once you have those two boards mounted, you can screw a piece of plywood to the bottom of those, forming a shelf for the amps.
Here's mine. It aint pretty, but it works and it does not make a sound.
http://img.photobucket.com/albums/v6.../glass0012.jpg
Old May 1, 2005 | 10:27 PM
DerrickM's Avatar
Cool!!
Old May 1, 2005 | 11:46 PM
Holy crap.. what did you do? looks like a science fair project, but I like the functionality. I'm like you ... who cares if you don't go to competition and all that...
I would paint those though like grey or something.
Old May 2, 2005 | 12:21 AM
El Presidente
lol whatever works!
Old May 2, 2005 | 10:23 AM
Question Well Alrighty Then
So, around how much power wire do you really think I need to go to center of the rear deck of the trunk? 2000 TL
Old May 2, 2005 | 03:08 PM
i had 20' of power wire in my kit...
heres my engine bay..
no slack at all... and it JUST made it to the ski hole of my trunk....
either i installed it wrong... or it can use an extra feet or 4... better to buy more than less? since you can always shorten it..
Old May 2, 2005 | 03:14 PM
Red face
Ok this guy will sell me 23 feet with his kit.. that should be okay then right?
I won't need any more than that hopefully.
Acura604
20
Aug 5, 2017 12:55 AM
Jul 16, 2017 07:33 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
