how to hardwire radar
Its easy, search the forums and you should find pics, but if you look to the left of the steering wheel there's a panel for your fuses (check out your owners manual). I wired mine to the windshield wiper fuse, I think its #33 or #13, but once again, check the manual, it'll tell you. I just wrapped the positive wire around the fuse and stuck it back into the socket, then the negative goes to the big bolt to the right (you'll see it). I didn't even have a hardwiring kit, I just cut off the cigarette lighter adapter part of the power cord and stripped the wires.
It ended up being really easy, I was surprised. You might have to pull off the a-frame plastic to get the wire to fit into the fuse box cleanly, but thats simple too, just pull it off, and when you're done press it back on. I'd take pics but I don't have my digi cam right now, maybe someone else on here can post pics (or search the forums).
chrisr
12-04-2015 03:17 AM
sockr1
10-01-2015 02:31 AM
