How Do U Take...........
Old Sep 4, 2004 | 12:02 PM
how do take out the stock speakers, do u just pull off the front cover?
Old Sep 4, 2004 | 12:14 PM
indoMFP's Avatar
What your problem is?
S5nake, are you talking rear or the front?? The front the entire door cover needs to be removed to access the speakers, just like in most other Honda products..... the rear I think there are clips underneath that need to be loosened...but aside from that it just comes right off...(don't qoute me on that)...
Old Sep 4, 2004 | 12:15 PM
do you know the steps to remove it?
thanks
Old Sep 4, 2004 | 12:18 PM
indoMFP's Avatar
give me a few, I will be back...
Old Sep 4, 2004 | 12:26 PM
indoMFP's Avatar
yo bro, the front door and the rear door have two screws that need to be removed.... then there is a clip for the door handle (from the inside) that needs to be disengaged. You have to pry the skin from the actual door.... do this carefully... The rear door is the same but the second screw is a lot deeper, so you need a long philips screwdriver....
For the rear sub, there is a cover that needs to be removed and then the screws that hold it in will be exposed...
You might want to post this question in the audio subsection because a lot of guys have done this (I have not, I am going off diagrams) they should help ya out... late.
