How Do I Get Full Range to the Back 6x9's????
Old Apr 3, 2010 | 06:02 PM
Bossman53's Avatar
5th Gear
Unhappy How Do I Get Full Range to the Back 6x9's????
I have an 06 TSX and i want full range 6x9's in the back shelf. How would i do this since the only freq going back to them is the low freq! Please let me know!!
Old Apr 3, 2010 | 11:47 PM
DurgyNess's Avatar
Not to say i know tons about any of this but
a. Run wires from the other speakers to the rear.
b. pull out the amp and re wire to bypass the amp which i heard is a pain in the butt
Old Apr 3, 2010 | 11:55 PM
sj993's Avatar
I would guess you probably have to rewire around the amp, though I don't even know where the amp is.
Old Apr 4, 2010 | 08:12 AM
elliott44k's Avatar
the amp is behind the not an ashtray
Old May 15, 2010 | 08:26 PM
newfie939's Avatar
5th Gear
Well if you don't want/need sound in the back doors, you can rewire the plug on the stock amp and switch the rear door speaker outputs with the 6x9 outputs.
You would not be able to bypass the amp from my understanding since you do not have a speaker level output coming out of the head unit.
If you parallel off another speaker input you will lower the impedance and cause issues with your amplifier being able to produce enough power to drive the new load.
Feb 25, 2020 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
02tljj
Sep 11, 2015 12:37 PM
KillerG
Sep 4, 2015 02:02 PM
