how can i trigger the alarm with a wire?
Old Oct 11, 2000 | 08:42 PM
mr tl's Avatar
Post how can i trigger the alarm with a wire?
i can only think of the dome light wire. any better ideas?
Old Oct 12, 2000 | 01:57 AM
Guest
Guest
Posts: n/a
Post
There are a couple of ways to trigger the factory alarm. One is to put a 12V pulse to the dome light wire. Another is to put a ground pulse to the hood sensor wire(behind grill). A last is if there is an additional instant trigger wire hooked into the alarm module. I don't have the wiring diagrams for the alarms so I'm not sure of the specifics.
Old Oct 12, 2000 | 02:04 AM
Guest
Guest
Posts: n/a
Post
I forgot one, on the Honda factory alarms they have ignition sensing so if you put 12v to your ignition wire for a second it will set off the alarm. This one is the last option if all else fails. (not really a good idea but it will work)
Old Oct 12, 2000 | 02:07 AM
NSX4dr's Avatar
Original Member #81
Post
Hood pin on factory alarm???????
Comptech exhaust
Comptech springs
custom air intake
18x7.5 Alstadts w/ 53mm offset
225/40/18 Kumho Ecsta Supras
193hp @ the wheels....soon to be
250hp @ the wheels....13's here I come
Old Oct 12, 2000 | 02:26 AM
Guest
Guest
Posts: n/a
Post
The is a wire that attaches to the latch on the front hood. This wire is hooked together with the trunk latch to sense when it is open. THe wire is open at rest.
Old Oct 12, 2000 | 07:57 AM
mr tl's Avatar
Post
yeah, those were the ideas the helm manual gave me. i'll decide which to use tonight
thanks
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
