how can i trigger the alarm with a wire?
i can only think of the dome light wire. any better ideas?
There are a couple of ways to trigger the factory alarm. One is to put a 12V pulse to the dome light wire. Another is to put a ground pulse to the hood sensor wire(behind grill). A last is if there is an additional instant trigger wire hooked into the alarm module. I don't have the wiring diagrams for the alarms so I'm not sure of the specifics.
I forgot one, on the Honda factory alarms they have ignition sensing so if you put 12v to your ignition wire for a second it will set off the alarm. This one is the last option if all else fails. (not really a good idea but it will work)
Hood pin on factory alarm??????? http://www.acura-tl.com/ubb/eek.gif
------------------ Comptech exhaust Comptech springs custom air intake 18x7.5 Alstadts w/ 53mm offset 225/40/18 Kumho Ecsta Supras 193hp @ the wheels....soon to be 250hp @ the wheels....13's here I come https://smilecwm.tripod.com/net6/lew.gif |
yeah, those were the ideas the helm manual gave me. i'll decide which to use tonight
thanks |
