how to add a sub but keep current stock amp?
Old Feb 23, 2003 | 03:41 PM
acuraman32cl's Avatar
Lone CL-P Owner
hey, i really have no experience with car audio (just mechanics) and i was wondering if there is a way to add a 8" sub in my trunk and plug it into my stock bose amp. i dont have too much money so i cant go all out but i just want a bit more base.
Old Feb 23, 2003 | 03:49 PM
mcdanjw's Avatar
You won't be able to plug a sub into the stock amp, directly.
You will need either a powered sub (like an Infinity Basslink) or an sub and amp combo. My friend got a brand new Basslink off eBay for $220 shipped and it sounds good.
There are several ways to hook the additional amp to the stock system, all of which are pretty easy to do.
Hope this helps, even though it isn't exactly what you wanted to hear.
Old Feb 24, 2003 | 06:09 PM
beerknurd's Avatar
Busy Living
try this: http://www.crutchfield.com/S-gUiEYmV...sp?i=113WA62RC
every review i've read about it has been excellent.
Old Feb 28, 2003 | 12:54 AM
IWuvMyCL-S's Avatar
... and my CL-S wuvs me
I'd also like to add some more bass to my system but don't have a lot of $$$ to spend, and was thinking of a Basslink also.
I noticed another post where you mention that an easy way is to tap the wires going into the rear deck speakers as long as the amp/sub will accept this type of input. Does the Basslink allow for this easy setup?
Any advice would be great!
Old Feb 28, 2003 | 07:25 AM
mcdanjw's Avatar
Yes it does accept speaker level inputs. Hooking up the signal wires really is easy.
You will be able to tap a turn on lead in the trunk pretty easily (using the turn on lead for the stock amp) as well.
The hardest part of the install will be running a power wire from the battery to the trunk. Silvernight has some good instructions on the best way to route that wire floating around here somewhere.
Here's a link to Crutchfield's page on the basslink; speaker level inputs is what you were looking for:
Basslink
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
james357
Feb 13, 2016 02:37 PM
handsom-hustla
Nov 13, 2015 05:04 PM
Pegon95
Sep 15, 2015 01:54 PM
yahelou
Sep 6, 2015 09:12 PM
