Hood latch- rattling
Old Oct 21, 2004 | 04:44 PM
big mike 13's Avatar
hi i posted a couple days ago about my new subs.... eveyrthing is basically rattling in my car... i suppose dynamat wil help the trunk..
but something UNDER my car (and i dont know what) and also my hood latch is rattling... when i hold down on the hood tip it stops, cna anyone tell me what i can do to stop it and any other recccomendations about under my car?? thanks!
Old Oct 21, 2004 | 04:46 PM
NYZGREATST's Avatar
Sig Rho's Finest
holy shit, what are you running that makes your hood rattle?!
Old Oct 22, 2004 | 02:05 AM
im only running 2 Incriminator Audio Lethal Injections (500 watts each).... or maybe my car is falling apart..
Old Oct 22, 2004 | 09:32 AM
ResidualFreedom's Avatar
2400 Watts in a TL...Why?
Mike, there are rubber stoppers in the hood just like in the trunk... I'm sure you know about the way to remove the rattles from the trunk, do the same to the hood..
For others that don't know the way to remove "most" of the rattles from the trunk.... There are rubber stoppers that are threaded on one end and screwed clock wise into the hood and the trunk.. To give more resistance when the hood and trunk are closed, hence minimizing alot of the rattles, just turn the rubber stoppers counter-clockwise a few turns, I think they only turn three or four times total, they have wide threads.
Once I did this to my trunk I eliminated almost all of the rattles coming from the trunk lid and hood.... I now am hearing more rattles from other places, sunroof and the plastic insert in the visor too!
If you have any suggestions on the sunroof rattle....help me out...
Keep us informed on the undercar rattleing, I'll check mine as well...
Patrick
Old Oct 22, 2004 | 12:42 PM
residual freedom... i heard about rubber stoppers but are they actually in teh car already?? right know i have some bright ass towels sticking out of my trunk (yellow and blue, on a black car) to try to stop the vibration... but if these stoppers are in the car already thats great
Old Oct 22, 2004 | 12:57 PM
yep they are in the lid... there are two different "style" stoppers in the lid of the trunk.. I have unscrewed the two on the outside (the larger ones). The two on the inside are pertruding through the "carpeted" plastic trunk lid inlay, the two on the outside do not come through the carpeted part in the lid, they are on either side just outside the "carpet".
When I found them it was like night and day..... now you can actually hear the bass outside the trunk without the embarrassing rattle...
Old Oct 22, 2004 | 10:34 PM
residual...
thanks a lot for all your help.
do you think a car can start "falling" apart from a system?? either its me or i notice each time i hit a bump now something is squeeking/rattling, either my roof or door...
and when i open the window halfway and close the door, the window bangs around (is yours tight (can you move it towards you and into the car) or is it rtight?? i hope im paranoid.
Old Oct 25, 2004 | 11:21 PM
Don't think my window moves that much.. I'll check though.
can u go more in detail on how to remove the trunk rattles, it sounds like crap and i dont quite understand how u guys did it.
If you open your trunk, look on the LID of the trunk.. There will be four rubber stoppers in the LID of the trunk.. two different kinds of stoppers and two of each kind, hence the total of four. Now the two stoppers on the outsides are threaded into the trunk lid, simply unscrew the stopper a couple of turns.... The rubber stoppers will be out a little further now... so when the trunk closes...it pushes up harder, eliminating most of the rattle..
The rattle comes from the trunk being "loose" enough to "shake" while it is in the latch... With the trunk pushing up it holds tight to the latch and stops mostly all of the trunk rattle... now you will probably hear the licence plate rattle instead of the trunk..
I hope that was a little clearer..
Patrick
bluetl04
Aug 16, 2016 02:49 PM
Bielikb96
Sep 28, 2015 10:45 AM
dirleton
Sep 28, 2015 07:05 AM
MilanoRedDashR
Sep 27, 2015 10:15 PM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
