hissing sound with factory head
Just had a system installed (two amps; 12"; 6x9's; 6 1/2's) connected to the factory head. There is a hissing sound that is audible when the system is turned on. Would using a better line out converter help to eliminate this problem? Please advise.
i also have 2 amps, 1 hooked up to the factory speakers and 1 to the sub, with the factory head. while the sound is real good at higher volume, the hissing sound will not go away at low volume. i've heard several setups done in this way and they all give the hissing noise. the only fix i know is to get an aftermarket headunit. i like the setup though.
09-15-2015 06:44 PM
