Help with System Question
Old Mar 20, 2004 | 10:42 AM
TypeSClik's Avatar
Ok I have a problem. I am wanting to get the following set up in my car:
Pioneer AVH-7500 DVD
Pioneer TS-AS6990R 5 way 6X9's
Pioneer TS-A640P 4 way 6 1/2's
2 JL Audio W6V2's
2 JL Audio 500/1 Amps
1 JL Audio 300/4 Amp
The guy I am getting the stuff from says that the best setup for that sub is to have 3 of them. I'm not to up on systems and what not so is this guy just trying to get me to buy more stuff from him or will this stuff not work well with each other?? Oh and does Pioneer have a new headunit coming out superior to the 7500?
Old Mar 20, 2004 | 11:28 AM
Chinisimo's Avatar
did he say what the extra amp is for? maybe he wants you to run 1 amp for each sub?
Old Mar 20, 2004 | 11:30 AM
TypeSClik's Avatar
I just figured I would need an amp per sub since the RMS on the subs are about 400. Was I wrong in assuming that??
Old Mar 20, 2004 | 02:04 PM
Dem1K's Avatar
Got a Job!
just get the JL 1000/1 amp, fuck getting 2 of the other amps...you'll save money this way.
Old Mar 20, 2004 | 04:25 PM
Nicky Pass's Avatar
Fuct in the hed!
Get 1 10W7 and 1 500/1....thats more than enough!
Old Mar 20, 2004 | 04:27 PM
TypeSClik's Avatar
I want to 2 just for the look. But I think I will go with the 1000/1 and then drop the ohms down to 1. Does that sound like a fix to my problem??
Old Mar 20, 2004 | 05:24 PM
Dem1K's Avatar
Got a Job!
I personally would go Nicky's route, as I plan on doing so VERY soon...however if you want 2, as I mentioned, get the 1000/1 and you'll be set
Old Mar 20, 2004 | 10:36 PM
melopats's Avatar
What the guy means is the subs! JL W6 subs work much better in 3's. I had 2 12's in a CRX and then when I got my Tahoe I put 3 10's and couldn't believe the difference. Just the way JL works. Looks hot too if the setup is done right witht he subs. Hope this helps!
Old Mar 21, 2004 | 12:56 AM
Nicky Pass's Avatar
Fuct in the hed!
I've been hearing that JL is haveing problems with thier 1000/1s, I know two people had them blow up. I'd get the 2 500/1s.
Old Mar 23, 2004 | 12:24 AM
TypeSClik's Avatar
I think I will go with the 2 500/1 amps and the two JLW6v2
Old Mar 23, 2004 | 12:27 AM
Dem1K's Avatar
Got a Job!
aer u gonna get 2 12's? btw, the w6v2 sound great, i had one before
Feb 25, 2020 09:57 AM
heykosal
1G RDX Problems & Fixes
Sep 21, 2015 09:41 AM
datadr
Sep 12, 2015 09:12 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
