TL: help speakers turning off
Old Oct 9, 2010 | 02:39 PM
dc2kid's Avatar
so i installed brand new alpine speakers all around the front has tweeters and the only problem is they are turning off when i blast the volume to 20 or so the deck is also alpine the new w505 i checked all the wiring and taped everything up but its still turning off,
the deck doesnt turn off though but does anyone know what the problem could be?
Old Oct 13, 2010 | 09:56 PM
Jonesi's Avatar
Did you try and contact alpine for some support? Initial thought is something is overloading and causing the headunit or amp to go into protection.
Old Oct 14, 2010 | 09:13 AM
fourthmeal's Avatar
Alpine may be using a polyswitch on their tweeters, which is a thermal protective device that cuts them out until the crossover has cooled down.
Pop the crossover boxes, you should see a polyswitch. This is what one looks like
So one thing that could be happening here is that with deck power, you might be clipping the signal thus the polyswitch is protecting. Not sure, but if you have an amp attached this might not happen. Either that, or you are playing much, much louder than these wee little speakers can handle.
Old Oct 14, 2010 | 09:14 AM
fourthmeal's Avatar
BTW, you said "taped up", but please god tell me you mean soldered THEN taped up. You didn't just twist wires together and use electrical tape, did you?
Old Oct 14, 2010 | 12:53 PM
Chris.'s Avatar
Yes what fourthmeal said, you are overloading these ie: too loud. The built in resistor or polyswitch is cutting your tweets off. Ive seen it a lot with mtx's and low end co-ax 2 way speakers. Solutions: 1.turn down treble 2. Turn down music 3. upgrade to better speakers ie: 3 way's or my personal fav, any infinity speaker 4. Amp them (4ch)...Good Luck
Feb 25, 2020 09:57 AM
handsom-hustla
Nov 13, 2015 05:04 PM
akbears15
15
Nov 5, 2015 07:06 AM
Pegon95
Sep 15, 2015 01:54 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
