HELP on Orion AMP!
Old May 17, 2003 | 11:35 AM
GOT PSI?'s Avatar
It's Go-Time.
HELP on Orion AMP!
I have the original Orion 250 HCCA amp with an external bridging module. I have had this amp sitting for years and have lost all the cables. I have called Orion directly and they don't have any info on the amp?!?
Can anyone help me out how to get the cables or have an owner's manual?
Old May 17, 2003 | 12:30 PM
JaySyn77's Avatar
If I'm not mistaken...the module is only needed if you plan on running the amp in mono. In reference to getting a manual, you may wanna create a post on either soundomain.com or termpro.com .... they both have great forums. Were you looking for the wiring that connects to the module? Is this the red HCCA Amp or the Black ones?
I can't believe ORION has no info on the amp
Old May 20, 2003 | 08:24 PM
GOT PSI?'s Avatar
It's Go-Time.
I want to run the amp 2 ohm mono. Orion was taken over by Directed Electronics a while back - I spoke with one of their techs and he said they don't keep old info kicking around anymore.
Yes, this is the red amp.
Old May 20, 2003 | 09:24 PM
JaySyn77's Avatar
Go to the 2 sites that I mentioned in my previous post and I'm pretty sure someone will help you out with the info you're requesting. Someone should be able to hook you up with a copy of a manual. I know these are the specs of that amp...really nice amp.
ORION HCCA250
50w x 2@ 4ohm
100w x 2@ 2ohm
200w x 2 @ 1ohm
400w x 2 @ .5ohm
200w x 1 @ 4ohm
400w x 1 @ 2ohm
800w x 1 @ 1ohm
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
Pegon95
Sep 15, 2015 01:54 PM
