HELP on Orion AMP!
It's Go-Time.
HELP on Orion AMP!
I have the original Orion 250 HCCA amp with an external bridging module. I have had this amp sitting for years and have lost all the cables. I have called Orion directly and they don't have any info on the amp?!?
Can anyone help me out how to get the cables or have an owner's manual?
If I'm not mistaken...the module is only needed if you plan on running the amp in mono. In reference to getting a manual, you may wanna create a post on either soundomain.com or termpro.com .... they both have great forums. Were you looking for the wiring that connects to the module? Is this the red HCCA Amp or the Black ones?
I can't believe ORION has no info on the amp
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
It's Go-Time.
Yes, this is the red amp.
Go to the 2 sites that I mentioned in my previous post and I'm pretty sure someone will help you out with the info you're requesting. Someone should be able to hook you up with a copy of a manual. I know these are the specs of that amp...really nice amp.
ORION HCCA250
50w x 2@ 4ohm
100w x 2@ 2ohm
200w x 2 @ 1ohm
400w x 2 @ .5ohm
200w x 1 @ 4ohm
400w x 1 @ 2ohm
800w x 1 @ 1ohm
ORION HCCA250
50w x 2@ 4ohm
100w x 2@ 2ohm
200w x 2 @ 1ohm
400w x 2 @ .5ohm
200w x 1 @ 4ohm
400w x 1 @ 2ohm
800w x 1 @ 1ohm
InFaMouSLink
10-30-2015 09:43 AM
4drviper
09-23-2015 09:00 PM
Pegon95
09-15-2015 01:54 PM
