Help with navi-dvd converter install
i did a search and cant find the thread im lookin for.
I installed Doms navi converter and i got one problem, the picture does not hold. its flickering horizontally. Im pretty sure i saw the solution to that problem in a past thread but i cant find it now . i 2x, 3x checked the wiring and the ground but no luck. Any input appreciated, thanks
Did you install an in line filter? That may be the problem. I never had that problem installing mine because I put a power filter in line with the power wire before ever turning it on. I think that may be it.
Radio Shack $16 DCV noise filter!
Registered User
mine did that too at first
my problem was i did not hook up the power or the ground for the converter, i forgot which one it was, but i figured i was not using it do it didn't matter, but it did
After 4 hours of going over every wire that was connected, in this crazy humidity too , i finally realized that the wire hookups in the instructional paper was wrong. . If anyone else has the same issue, make sure that the synchro wires (in and out from the D9 cable) are going into the same colored factory wires. I had originally thought i was having grounding issues
Registered User
cycdaniel
12-17-2019 10:58 AM
IIDXholic
10-08-2015 07:53 AM
Skirmich
09-15-2015 06:41 PM
alan_rich
09-07-2015 11:08 PM
