Help with Metra Kit and Alpine 9835
Old Dec 19, 2004 | 03:05 PM
Cdn A-Spec's Avatar
03 TL-S A-Spec
I just put my system together and the alpine deck sits in about 1/2 inch from the from of the Metra kit? What's up with that. Any suggestions?
Old Dec 19, 2004 | 03:51 PM
DerrickM's Avatar
post a picture. the metra is generally held in high regard for quality. Any chance you put the two side piece on the wrong place ( i mean the wrong screw holes)?
Old Dec 19, 2004 | 07:06 PM
Cdn A-Spec's Avatar
03 TL-S A-Spec
I didn't screw anything in, the deck slides into the DIN sized hole. I tried to use the supplied Trim Plate, but that didn't work either. Here is the pic from the side and one from the front (plus stay in the album to see the rest of my system):
http://www.acurainspired.com/gallery...oadSlideShow=2
I saw a thread with another Alpine deck using the supplied trim ring, so I know it is supposed to sit right.
Old Dec 19, 2004 | 08:10 PM
DerrickM's Avatar
Hmmm, strange. So, you used the plastic side clips that came with the kit? And you didn't have screw holes to bring it out a little? (And when you attached them to the radio, they supported it from the bottom, right?)
The trim ring that I see in the pictures, is that seperate from the Alpine, or part of it? The HU looks good at that depth, but the trim ring seems too far back--so I'm wondering if there's any way to bring it forward...
Old Dec 19, 2004 | 08:54 PM
Cdn A-Spec's Avatar
03 TL-S A-Spec
I didn't use the little side pieces. They won't go in the DIN slot with the Deck, it's too wide.
Old Dec 20, 2004 | 07:56 AM
DerrickM's Avatar
Oh. Seems like a lot of people here have Alpines, maybe we can get one of them to reply.
Anybody?
Old Dec 21, 2004 | 11:48 PM
hellas's Avatar
that ring thats attached to the front of the head unit, take it off. it snaps off
then attach the brackets to the headunit, making the unit flush with the face.
snap in the trim ring that came with the kit, to cover the gap
Old Jan 4, 2005 | 08:29 PM
Cdn A-Spec's Avatar
03 TL-S A-Spec
I'll give that a whirl this weekend. Thanks.
Old Jan 5, 2005 | 10:10 AM
fpique's Avatar
NorCal you Beezy!
I have the same deck... mine sits alittle back but not as noticable as yours. Alpine decks on other brands.
You might want to double check which holes you screwed the screws into.
Good Luck
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
