Help Me!
Re: Help Me!
Originally posted by HebrewNational
Where did you guys connect your remote wires for after market amps?? Every fuse I try leaves the amp on after I turn off the car. I am really frustrated. TIA
Go here and locate the wiring color coded table. Locate "Radio Switch" wire. It should be Yellow/White.
So I can just splice the " switch " wire to my blue remote wire from the amp? Thanks for the link it gave me some good ideas. feeling better about this whole project now
I am so glad about that switch line! I got so ticked when all the fuses in the fuse box stayed live all the time. I am planning on using two sided insulation tape to stick my 6x9s in the back. I just purchased the new infinity kappa 3 ways. They freakin rock
I have failed! I tried running the ylw/wht wire into my amp. It came on and stayed on. Maby I need some very specific directions. Should I use the cable going into the amp. Thats the one I used. Any info is great!
Theres 2 yellow and white wires I believe... the one you want is the smaller gauge of the two. Whats the deal with the 2 sided insulation tape to put speakers in??????? you gotta screw those puppies down!! not tape! Use the screws that held the stock speakers in place.
I did everything to spec from the pictures. I tied into the line for the radio switch going into the amp. I can try again, is there any thing I could have done wrong? At least I had time to secure my speakers.
I thought I would be able to borrow a digital cam from a buddy but he does not have it at the moment. If you have any closer pics of the specific wire to attach my remote to that would be awsome. I pulled everything out, maby I will just do it again during the day time w/o the help of any beer
