Help Me!
Old Oct 31, 2001 | 09:43 AM
HebrewNational's Avatar
Help Me!
Where did you guys connect your remote wires for after market amps?? Every fuse I try leaves the amp on after I turn off the car. I am really frustrated. TIA
Old Oct 31, 2001 | 11:20 AM
SilverKnight's Avatar
Retired. Not available.
Re: Help Me!
http://silverknight.clickhere2.net/sound.html
Go here and locate the wiring color coded table. Locate "Radio Switch" wire. It should be Yellow/White.
Old Oct 31, 2001 | 11:40 AM
So I can just splice the " switch " wire to my blue remote wire from the amp? Thanks for the link it gave me some good ideas. feeling better about this whole project now
Old Oct 31, 2001 | 11:45 AM
Yup. Do that. Didn't you see the link in my sig before? Maybe I should make the font super large
Old Oct 31, 2001 | 11:50 AM
I am so glad about that switch line! I got so ticked when all the fuses in the fuse box stayed live all the time. I am planning on using two sided insulation tape to stick my 6x9s in the back. I just purchased the new infinity kappa 3 ways. They freakin rock
Old Nov 1, 2001 | 08:53 AM
I have failed! I tried running the ylw/wht wire into my amp. It came on and stayed on. Maby I need some very specific directions. Should I use the cable going into the amp. Thats the one I used. Any info is great!
Old Nov 1, 2001 | 11:01 AM
SumkidwithaCL's Avatar
Turn Signals are good!
Theres 2 yellow and white wires I believe... the one you want is the smaller gauge of the two. Whats the deal with the 2 sided insulation tape to put speakers in??????? you gotta screw those puppies down!! not tape! Use the screws that held the stock speakers in place.
Old Nov 1, 2001 | 12:04 PM
Dont tell me you get use the Yellow/White wire from the fuse box. This wire is in the back where the Bose amp is. Assume your power wires to the amp is correctly installed, there is no way the amp would be on and stay on when the HU is off. Oh yeah, given the fact your head unit is stock, too.
Old Nov 1, 2001 | 12:41 PM
I did everything to spec from the pictures. I tied into the line for the radio switch going into the amp. I can try again, is there any thing I could have done wrong? At least I had time to secure my speakers.
Old Nov 1, 2001 | 03:07 PM
Snap couple pics of your wiring at the amp and at the harness so I can see.
Old Nov 1, 2001 | 04:50 PM
I will try and take pictures in the next day or two. Thanks for helping out.
Old Nov 2, 2001 | 11:52 AM
I thought I would be able to borrow a digital cam from a buddy but he does not have it at the moment. If you have any closer pics of the specific wire to attach my remote to that would be awsome. I pulled everything out, maby I will just do it again during the day time w/o the help of any beer
Old Nov 2, 2001 | 11:56 AM
Yeah one PIC of the wire would prob solve all my problems....the amp ones at least
