Help with Kenwood GPS wiring
I have the kenwood ddx-7017 and purchased the plug-in GPS unit. there's a couple wires i need to connect and wanted to know a few things...
Ground (Black)
Battery 12v (Red)
Ignition 12v (Yellow)
Parking Brake Sensor (Green)
Ground is easy.
Red/Yellow, can i just tap the same red/yellow on the radio wire harness? I assume it's the same thing as battery and ignition.
Parking brake sensor, can i just ground this wire out? There's a speed sensor wire on the kenwood unit so that it won't play dvds while in motion, but i just grounded that out and now it plays all the time. I figure the parking brake sensor is the same.
Thanks in advance.
PS. where should i mount the antenna? I was going to put it on the rear window but i have 5% tint, will that matter?
Ground (Black)
Battery 12v (Red)
Ground is easy.
Thanks in advance.
blacktsxwagon
Oct 27, 2015 10:12 PM
SUPRMN84
Oct 7, 2015 09:46 PM
