Help with installtion on top of what i have
Old Mar 23, 2009 | 08:39 PM
SanJoseRoller's Avatar
I SMELL NAWZ
Whats up guys,
I have a TS-W3001D2 subwoofer in a 2 cu ft ported box with a 1000.1 amp mono block. The subwoofer is wired up with 4 gauge wiring and i am using a high low converter thing so that i can retain my factory stereo. This is all in a 01 Audi A6.
The car has been running well, but i am ready to replace the factory BOSE speakers. In terms of speakers i wanted to buy 2 sets of components 6.5's for a total of 4 mids and 4 tweeters. I am also looking to buy a 4 channel amp strong enough to power the component setup i want. With the addition of a new amp "the 4 channel" will i have to run seperate power / rca lines for that amp or could i just somehow splice the 4 gauge power line from my mono amp and link it to the speaker 4 channel amp? Im not 100% sure but someone told me to get a power doc station so that i could utilize the same power line from my mono amp. And as far as the RCA goes im not even sure how to deal with that. WIll i have to run seperate RCA's or can i somehow splice into my mono amp RCA's? sorry for the dumb questions this is all new to me
Old Mar 23, 2009 | 08:56 PM
mattastick's Avatar
Are you wanting to keep the factory head unit, or replace that as well? If you're keeping your factory HU, you'll need a 4 channel LOC, and an amp that has a pass-thru RCA out. Then, you're probably going to want to run 1/0 power & ground wire from your battery to a distro block in the trunk then 4g wire from the block to the amps. As for speaker wire, I'd run all new for your 2 sets of comps. The RCA's would come from your 4-channel LOC (if you're not replacing your factory HU) to your 4 channel amp, through the pass-thru, then to your mono amp for the sub... This would provide signal for both amps. I think I answered all your questions, but I'm not sure... If I didn't, feel fre to ask again, and I'll answer when I see it...
IBankMouse
Jun 13, 2020 12:53 PM
joflewbyu2
Aug 18, 2019 10:38 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
Oakroadsteve
Oct 28, 2015 10:28 PM
jmaxima03
Sep 27, 2015 10:22 AM
