help installing power cable from amp to battery
Old Feb 15, 2005 | 11:26 PM
how do i run the power cable from the amp to the battery on a 2000 TL?
the amp is located in the trunk and i am running it through the side door panels up to the front dash. how do i get the cable to the battery?
firewall? any other way?
where is the firewall located?
how do i run it through the firewall? (cable is thick)
thanks for the help or ideas
Old Feb 15, 2005 | 11:44 PM
DerrickM's Avatar
see the thread (used to be sticky) "Comprehensive data on 2nd gen TL":
https://acurazine.com/forums/audio-video-electronics-navigation-22/comprehensive-data-upgrading-2nd-gen-sound-system-tl-263649/
Moderators--can we get that restuck?
Firewall is the wall forward of the cabin. There's a grommet above the gas petal that you can go through. More details on the link above.
Old Feb 16, 2005 | 12:04 AM
dark inspire's Avatar
El Presidente
u could also run it thru the side of the engine compartment above the fenderwell of the tire and into the cabin through the gasked behind the door hinge then down the doorsills.
Old Feb 16, 2005 | 01:16 AM
elduderino's Avatar
VP Electricity
Finally someone else with my fave amp-wire route!
Old Feb 16, 2005 | 08:53 AM
i did that before, but isn't that a fire hazard
Old Feb 16, 2005 | 10:16 AM
elduderino's Avatar
VP Electricity
You ARE installing a fuse, right?
A lot less can happen to that wire in the inner fender space than in the engine compartment. Takes a crash to hurt it, the plastic inner fender material protects the wire (and the factory harnesses also in there: )
Old Feb 16, 2005 | 12:19 PM
El Presidente
yeah bro, u better be installin a fuse if u dont want ur system to get
Old Feb 16, 2005 | 12:27 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Fuses are overated
Old Feb 16, 2005 | 01:37 PM
elduderino's Avatar
VP Electricity
Originally Posted by Tsx536
Fuses are overated
Yep... by 50% for five seconds, if memory serves.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
Pegon95
Sep 15, 2015 01:54 PM
usdmJON
Sep 4, 2015 12:59 AM
