Help with amp Install
Old 02-10-2004, 05:22 PM
360's Avatar
Im installing an amp and sub in my girls car. for v day. i've got the amp installed and trying to use the high level speaker inputs for my source. I tapped the rear speakers ,when the cars on it works fine but when i turn off the car and then turn on it on again the speakers stop working . all of them when i disconnect the amp they start to work. and hook them up again its working only when i turn off the car they stop. need help
ASAP!
shes leaving for a trip tommorow.
Old 02-10-2004, 05:59 PM
My Member is Registered
Cruz_msl's Avatar
It sounds like you may have accidentally attached a switched hot wire from your fuse panel into a constant hot on the amp.
Hope this helps
Old 02-10-2004, 08:47 PM
360's Avatar
thanks
I just bought a line convert and that did the deal
AndrewS
19
03-14-2024 06:59 PM
jpadilla
3G RLX (2013+)
11-18-2017 07:13 PM
giovane
2G RDX DIY & FAQ
07-08-2016 10:46 PM
TxRzrBk
09-17-2015 01:07 PM
Pegon95
09-15-2015 01:54 PM
Quick Reply: Help with amp Install
