TL: Help 05 TL VSA & CHECK ENGINE light on after amp install and sub
Old Jun 17, 2012 | 07:29 PM
dj_wun's Avatar
Want to know if anyone also had the same problem when installing sub and amp into factory head unit on a 05 TL. It was driving fine then when i parked then started back up the VSA and Check light turn on and i can't drive faster than 20mph. Anyone know what the problem might be? Thank you
Old Jun 26, 2012 | 11:22 PM
AcuraNH's Avatar
8th Gear
Well I know my 05 acura has an anti theft radio which is basically designed to never come out of the car. There are alot of sensors and wires that go from the computer system to every part of the car. I would think something got damaged when you took it out.
They designed low-level converters so you technically would never need to take the factory head unit out of such cars when installing aftermarket sound systems.
mada51589
Jan 9, 2025 04:40 PM
Skirmich
Sep 15, 2015 06:41 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
