headrest monitor install? for DIY
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
Just a quick install question. If you have or had headrest monitors installed how did you run the wires through the seat. The obvious answer would be to fish it threw with a coat hanger. Im just trying to find the correct and the best way to do this. Any info would be appreciated thanks
RS
RS
The easiest way is to remove the seat back - there are two pop clips at the bottom of the seat - if you have access to a door panel puller it will make you life much easier and you won't break the clips. Then the seatback slides down and out from the top.
cycdaniel
12-17-2019 10:58 AM
