CL: Headlights
Old Aug 6, 2010 | 12:15 PM
raulramos323's Avatar
Headlights
Hi i recently just got my 2001 Acura CL-S and was looking to install some aftermarket headlights i have looked everwhere online but could not find any does any one know where i can find some?
Old Aug 6, 2010 | 12:40 PM
mattastick's Avatar
If it's anything like the 1st gen, you have 1 option. Anything else, you have to build yourself...
Old Aug 6, 2010 | 01:14 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
There are no aftermarket headlights for 2nd gens, you can get 03 headlights or make your own
Old Aug 6, 2010 | 01:15 PM
will 03 headlights have a direct fit or will custom work need to be done?
Old Aug 6, 2010 | 03:06 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
03's will fit with no mods.
But it's alway better if you want custom ,you make custom.
Old Aug 11, 2010 | 10:08 PM
do you know of a place that does custom headlights in los angeles, or is a do it urself and if so any tips or how to do custom?
Old Aug 12, 2010 | 09:00 AM
(Mid-Atlantic)
Do it yourself
Old Aug 12, 2010 | 09:10 AM
mattastick's Avatar
The reason people do custom is so they can get exactly what they want. So for us to tell you what to do with your headlights doesn't make much sense.
Now, to get them apart, I've found that 200 degrees for 12 minutes in the oven works well. This is what works best for me. You will have to watch your headlights to make sure you don't burn anything. I'm not responsible if you fuck up your headlights by putting them in the oven. But what I do is grab a cookie sheet, throw some aluminum foil on it, and put the headlight on top of that. Then grab a couple screw drivers/pocketknives/whatever and pry the headlamp apart. After that, it's easy disassembly stuff and you can do whatever you want to your headlights. I'd suggest getting all of the stock silicone out, and replacing it with new silicone. Don't short the silicone when you're putting the housings back together. More is better. You don't want those nice new headlights you worked so hard on to leak...
Old Aug 12, 2010 | 11:01 AM
on1wheel01's Avatar
I do 250 deg for 7 mins. Works perfect
Old Aug 13, 2010 | 12:07 AM
neel101's Avatar
Hey i have a 03 cl-s and i have xenon headlights lights but one of my headlights turns off after the first 10 seconds after turning them on. so i simply turn them off and then turn them on and they stay on and dont give me any problems. any one have any suggestions?
Old Aug 13, 2010 | 12:12 AM
civicdrivr's Avatar
Ballast is going out.
Old Aug 13, 2010 | 12:16 AM
neel101's Avatar
how much does a new ballast run for?
Old Aug 13, 2010 | 09:13 AM
on1wheel01's Avatar
Depends on where u buy it from.
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
